Registering radically altered vehicles
Guidelines on how you can register radically altered vehicles (Rods)
Information taken from the INF 26 leaflet, Government web pages, NSRA Forum, UK Hot Rods and ACE
For more information go to www.direct.gov.uk/vehiclereg
1. Introduction
A vehicle must be properly taxed, insured and registered before it can be used or kept on the public road. When a vehicle is first registered, it is given a registration number which must be properly displayed on the vehicle's number plate. The registration number stays with the vehicle until it is broken up, destroyed, permanently exported or transferred to another vehicle by what is known as a 'cherished transfer'.
However, sometimes a vehicle needs to be rebuilt or it is radically altered and this can affect the identity of the vehicle - is it the original vehicle which has been repaired, or have so many new or different parts been used that the original vehicle no longer exists?
When giving a registration number to a rebuilt vehicle or radically altered vehicle the main priority is to decide whether or not the vehicle is newly built with no previously registered identity (in its present form). Vehicles which have been substantially rebuilt or altered from the manufacturer's original specification need to be examined at a DVLA local office who will check the vehicle record and history. Checks will be made to establish if the donor vehicle or major component parts have been subject to a Vehicle Identification Check (VIC) or Certificate of Destruction (CoD).
Vehicle Identity Check (VIC)
The VIC has been introduced to put criminals off disguising stolen cars with the identity of written-off or scrapped ones. The check is designed to help confirm that the vehicle being returned to the road has been repaired following accident damage and has not been stolen. For further information go to www.direct.gov.uk/vic.
Since April 2003, DVLA is notified of all cars that are written off by an insurance company or declared scrapped by their owners due to accident damage are notified to DVLA.
Any vehicle, which has failed a VIC, will not be entitled to keep its original registration number. A DVLA local office will allocate a 'Q' registration number and Individual Vehicle Approval (IVA), Single Vehicle Approval (SVA) or Motorcycle Single Vehicle Approval (MSVA) will be needed before the vehicle is registered.
If a VIC application is rejected by Vehicle Operator and Services Agency (VOSA) because the vehicle has been rebuilt, the DVLA local office will need to assess the vehicle in line with our rebuild guidelines.
Since 2003, cars, light vans and some tricycles (for example Reliant Robin) can only be scrapped at an Authorised Treatment Facility (ATF) who will issue a CoD certifying that the vehicle has been or will be dismantled in line with strict environmental standards. For further information go to www.direct.gov.uk/scrappingyourcar or refer to 'Certificate of Destruction' (INF156).
These vehicles must never re-appear as 'complete' vehicles or be presented for registration under these guidelines. Some minor components from a vehicle issued with a CoD may be recycled. The original CoD vehicle identity cannot be kept under any circumstances.
Vehicles with personalised registration numbers
Not all registration numbers are transferable. Check your Registration Certificate (V5C) first. You may want to arrange to transfer or retain the registration number before you carry out any alterations or conversions. For more information, see the 'Application to transfer or retain a vehicle registration number' (V317), or our booklet 'Registration Numbers and You' (INF46). You can get these from www.direct.gov.uk/motoringforms, www.direct.gov.uk/motoring leaflets or DVLA local offices.
Important - It is the responsibility of the vehicle keeper to ensure that their vehicle meets the Road Vehicles (Construction and Use) Regulations 1986 (as amended) if used on the road
2. Vehicles that have been rebuilt using a mix of new and/or used parts
To keep the original registration number:
Cars and light vans must use:
The original unaltered chassis or unaltered monocoque bodyshell (that is, the body and chassis as one unit);
or
A new chassis or monocoque bodyshell of the same specification as the original. A receipt from the dealer or manufacturer is required.
AND the vehicle must have two other major components - as listed below - from the original vehicle.
i. Suspension (front and back)
ii. Axles (both)
iii. Transmission
iv. Steering assembly
v. Engine
If a second-hand chassis or monocoque bodyshell is used, the vehicle must have Individual Vehicle Approval (IVA) (see section 11). A 'Q' registration number will then be issued.
3. Vehicles that have been radically altered
This covers vehicles which are radically altered from their original specification, but which are not kit conversions.
In these cases, the vehicle components from the original vehicle will be given a number of points. To keep the original registration number, the vehicle must have eight or more points, which must include the original or new unmodified chassis or monocoque bodyshell.
If the vehicle has less than eight points, a second-hand or altered chassis, frame or monocoque bodyshell is used, the vehicle must have IVA, so that it can be registered. A 'Q' registration number will then be issued,
The following points will be given to the original major components used.
i. Chassis or monocoque bodyshell (body and chassis as one unit) (original or new)
Direct replacement from the manufacturers - 5 points
ii. Suspension (front & back) - 2 points
iii. Axles (both) - 2 points
iv. Transmission - 2 points
v. Steering assembly - 2 points
vi. Engine - 1 point
4. Kit built
If all the parts of a vehicle are supplied new by the manufacturer, the vehicle will be allocated a current registration number as long as you provide satisfactory receipts and a Certificate of Newness.
Kit cars which have been built using no more than one reconditioned component will also be registered under a current registration number as long as you provide satisfactory evidence that the component has been reconditioned to an 'as new' standard. The vehicle must have IVA.
5. Kit Conversions (Rod built using new chassis/glass body)
This is where a kit of new parts is added to an existing vehicle, or old parts are added to a kit of a manufactured body, chassis or monocoque bodyshell. The general appearance of the vehicle will change and result in a different description being put on the Registration
Certificate (V5C).
A vehicle will keep the registration number of the original vehicle if the original unaltered chassis/monocoque bodyshell has been used along with two other major components from the original vehicle.
If a new monocoque bodyshell or chassis from a specialist kit manufacturer (or an altered chassis or bodyshell from an existing vehicle) is used with two original major components from the donor vehicle, a replacement registration number will be issued based on the age of the donor vehicle.
The vehicle must have IVA. The date of manufacture for the vehicle will be taken from the IVA certificate.
Where insufficient parts from a donor vehicle are used or in cases where the original registration is unknown IVA will be required to register the vehicle and a 'Q' prefix registration number will be allocated.
