SBC 355 & 383 cid turn key supercharged engines
TRADE: FASTCO AUTOMOTIVE PRODUCTS USA
NEW SERIES
Chevy 355 & 383 cid supercharged engines 100% turn key full show dressed & dyno tested
BHP range 450.....700+BHP on pump gas...prices start @ 4900 GBP /Chevy 355cid
Pic of our SBC 383 cid blower engine with Weiand 8/71 supercharger kit :cool:http://i4.photobucket.com/albums/y14...ps0b1d1102.jpg
These new series engines are built from the ground up for supercharging application
Quick specs: Chevy 355 & 383 cid
GM /HD blocks full CNC all oil mods also Dart & World block aval as options
Scat or Eagle or RPM crankshafts
Damper SFI tag'd for blown app
Bearings Clevite 77H or King Race
E/W connecting rods or Scat connecting rods / floating pin
Pistion KB forged 8.5 to 8.9:1 comp
E/W plasma moly rings file fit /gap'd to blower engine specs
Cam Comp Cams USA custom grind hyd roller for blown app
Lifters Morel USA hyd roller
Chain set Rollmaster true roller / billet steel gears , torrington brg cam thrust plate
E/W roller cam button...E/W ally timing cover with cam button pad
Sump RPC 7 QT SS or E/W 7 QT road race HV pick up with Melling HV 55 pump ARP drive
Heads E/W ally 200 to 217 cc runners 2.02 & 1.60 & 2.055 & 1.60 valves
Heads full CNC machined , or add 100% CNC ported as an option.
Dart & RHS & AFR & Eds heads aval an option.
V/T Comp hyd roller dual springs seat pressure set to blower engine specs.
10 degree moly retainers & 10 degree locks
Roller rockers Warhammer SS or E/W forged ally 7/16 stud mount
Head gaskets MLS for blower engine / heads stud mounted to block
Blowers Weiand 177 & 6/71 & 8/71 kits satin & polished
Carbs Edelbrock & QFT USA blower carbs
Ignition Revolution HEI & Outlaw billet, wires Mega Fire & MSD
All pulleys & mounts ally / satin & polished
Engines are balanced & blueprinted & dyno tested & tuned video of test & dyno printout supplied.
Also avaliable matching auto transmissions for these engines 350TH stage II rated @ 450HP and 700R4 trans rated @ 450 HP and 400 TH trans stage 2 rated @ 600 HP & Stage 3 rated @ 850HP trans are dyno tested with printout of test supplied also matching custom torque converters custom built for blown app with ballon plates 2600 stall to 4500 stall.
Transmissions ship FREE with engine.
Prices start @ 4900 GBP...eg Chevy 355cid with Weiand 177 blower Ed carb
Pic of Jeff's Chevy 355 cid supercharged engine.
http://i4.photobucket.com/albums/y14...GUNSCOOP-1.jpg
Contact Daryl @ fastcoauto@aol.com
For more info ...
Or call 1-716-471-4146
Cheers !
