3 Attachment(s)
Chevy 355 cid roller engine 390+BHP/ turn key / full show dressed short water pump
Attachment 33992
Attachment 33997
Trade: New Chevy 355cid / 390+ BHP full roller engine 100% turn key 4300 GBP landed UK
New 355cid / 400+ BHP roller engine 100% turn key classic hot rod dress kit with cog drive system
Quick Spec
GM block full CNC machined all oil mods
Scat crank 3.48 stroke
E/W 4130 rods 5.700 / floating pins
CL-77 bearings STD
Speed Pro hyper pistons 9.8:1 comp & S/P moly rings
Comp Cam hyd roller custom grind ..560 lift
Morel USA hyd rollers
True roller chain set 9 key crank gear E/W roller thrust button
RPC 7 QT sump . Melling HV pump ARP drive
NBK 200 cc runners heads full CNC 2.02 & 1.60 valves Comp roller VT Warhammer alum rollers Comp Cams adjustable guide plates.
Revolution HEI recurved Mega Fire wires NGK plugs
Full show dressed ally covers PVC & breather
100 Amp chrome aten billet alum mount kit
QFT 600 CFM carb
Big End 110 GPH fuel pump ARP pump rod
All lines SS braided hose with ally ends .
Engine Hines balanced with spec sheet
SFI flexplate ARP bolts 168 or 153 tooth
Duralast starter
Engine 100% turn k
Also aval; 350TH Stage II transmission with matching 10" 2800 stall T/C both ship free with engine
Price 4300 GBP landed UK @ Dartford or Liverpool seaports
Finned retro look and air scoops and cog drive system aval .....
Attachment 34004
1 Attachment(s)
A/C & P/S systems can be added
Attachment 34081
Been asked can we supply A/C & remote P/S system with our engine..... yes indeed we can .
