6 Attachment(s)
1939 STEEL Topolino Coupe & Roadster bodies & Chassis, First time offered.
First model Fiat Topolino. Perfect for your nostalgic build. Bodies 900 Quid each. Powdercoated chassis 300 Quid each. Four fenders/wings together for 200 Quid. Both bodies decent condition with work on the sills . Both bodies have had the floors patched up in the last 80 odd years , probably better to cut out and start again . For a race car you will cut out anyway. Lower doors have minimal rust, Both have good door hinges but on the grey coupe the hinges will need to be re-positioned ( use the same holes ) . Someone drilled out the mounting screws . Both bodies have door locks/handles. Size is 122 inch long ( 310cm ), 44 inch wide (112cm ), Cut off the useless rounded front under the grille will save 21 inch ( 54cm ) Can do that here if the body does,nt fit in your van or pickup. To work out distance i,m 3.5 hours from Calais , 1 hour from Rotterdam/Amsterdam. Postcode is 4005EX. 3 minutes from the freeway A15 where there is also a big hotel/casino. Then again in the past UK visitors have done the trip in one long day. PS, Man these pics are big, and i did resize too.
front and rear fender set.
hello, I am interested in a set of fenders (front and rear), could you ship to the uk? best regards Jacqui
