Early ford parts for sale.
Having a bit of a clear out to make some space, can ship everything apart from the chassis or collect CH64. Can send photos if any interest, just ask.
The forum is changing pound signs to question marks, so imagine the question marks are pound signs.
40 Ford Front brakes. Mounting holes slotted and early v8 garage adapter kit to put them on 32 onwards spindles. Shoes need re-lining. No cylinders. Recently blasted and painted but have been sitting about. ?200
40 Ford Front brakes Shoes need re-lining. no wheel cylinders everything else is there.?175
Flathead cylinder heads. All cast iron take offs, will need cleaning and skimming but no obvious damage?
Pr 37 21 stud centre outlet ?50
Pr Pilot 21 stud ?40
3 59A 24 stud ?50
32 Spare wheel carrier. Mounting ends have been messed with but easy fix ?40
292 Y Block. Disassembled for rebuild. STD/STD no ancillaries. Manual engine with flywheel. ?250 I have a y block to early Ford 3 spd adapter available at extra cost if engine sells.
39 Ford rear axle. No torque tube, bones or drums. Came out of a recently running and driving car. ?500
Model A headlights. Flat twolite lense type, not fluted. Some minor shelling to lenses and one has a small slither missing on edge. Reflectors need re-silvering but the bowls and rims are mint with no dents or damage. Would polish up like new. ?200
