Bad Ac - ah yes, Connolly hide care, that's what I'm using
Black Pop - when I built the Ruby, I only had 2 open ended spanners in Whitworth, so your socket set has been a great improvement!
Ivanhoew - Thank you
I had a go at the firewall today.
Attachment 59531
I removed the wing supports, they won't fit once the car is channelled, may be able to re use them somehow.
Attachment 59532
The firewall had a big box attached, bit of angle grinder noise and now...
Attachment 59533
That was all I had time for.
Good thing about it is, removable firewall means I can fit new engine and channel body, then alter the firewall to go back in.
What gearbox you thinking of using in the Morris? I'm fitting a zetec to my 32 Sedan, swaying down the route of the MX5 NC7, only down side is its a long box! or by the time you buy everything required for that, it works out the same as a good type 9! :confused:
Keep up the good work!
Thanks BadAC, Blackpop, Ivanhoew.
Today I didn't really have any garage time, although I did just go into the garage for 5 minutes, to load up some stuff I was taking to my sisters garage.
Then I thought "While I'm out here I'll just put all the tools away and move the engine hoist into position "
I didn't even have work clothes on.
Next thing I knew I'd removed the engine and gearbox, well I had undone the bolts already, and it's only small.
Attachment 59548
The St170 is small after the SBC, but the little Morris engine makes the St170 look big!
It's waiting for someone to buy it now. (The Morris lump, not the ST170)
Attachment 59549
Now I'm getting closer to being able to play with the chassis.
Coming on well Ian, but don't get your good clothes messy mate [emoji1]
Blimey your moving on. I don't seem to get time at mo.
Are you sticking to injection or going bike carbs.?
Great job.
Sent from my moto e30 using NSRA mobile app
Ricey- sorry, I only just saw your post. I'm hoping to get a type 9 in the next month.
The last zetec I had, I used a Mazda RX8 gearbox.
BadAC - yes I'm going to try and keep it all as standard as possible, using the injection. This will hopefully mean that I can get decent economy as well as plenty of performance.
Tim - I like working in old clothes or overalls , then I can get stuck in without worrying about spoiling good clothes. This was an exception.
Ha ha, I'm the same Ian, always have "playing out clothes" [emoji1]
Today I whizzed down the M2 in the Ruby, took the front axle of the Morris to My Gasser. Nice to see Neil and his workshop and projects. I guess Neil will post, either on here or on his own thread, when he has done the trickery with the axle.
Also thanks Neil for the loan of the big puller
Attachment 59557
The axle couldn't argue with this serious puller, the hub came straight off.
I made up a way of stopping the shaft turning on the other side and finally got the nut off, and did that side too.
I then needed a special tool, which according to the manual, is available at Mg dealerships. Hmm. I don't think so today.
Made up a puller for the shaft from a flat piece of plate.
Attachment 59558
Now I could see the halfshafts, it was clear that I can't have them resplined 3 1/4" shorter, they are waisted and don't have enough material to respline. There is a plan B though.
Also Neil let me have a 4 speed gearbox which is donating its bellhousing to the cause. I have arranged to collect a type 9 box which has no bellhousung.
great looking project, keep us updated..
All coming on Ian, always helps to have a bit of assistance with the tough bits mate. [emoji106]
years of working on dad's lorries has left me with lots of big boys tools :thumbs_up_smiley:
Thanks guys.
Here's the gearbox I brought back
Attachment 59568
I always think it's cool to collect parts for the rod your building in another rod.
Here's the halfshaft from the MGB axle
Attachment 59569
Not thick enough to shorten and respline, so I sent them by courier today to MyGasser who knows someone with a big lathe who can make a good job of cutting and shutting them.
Attachment 59570
Removed the original axle and prop today, and some tidying of the chassis, removing brake pipes etc. I'm always amazed how stuff unbolts easily from a 1930s car, whereas later stuff just rusts and sizes solid.
Quality of parts back in the day has a lot to do with it Ian. Coming on well mate. [emoji106]
Yes Tim, that is clearly the case.
Today I narrowed the axle casing.
I put a white line (Tippex) all the way across the axle to ensure I line everything correctly when welding it back together.
Then I marked it, and stuffed a rag down each side to prevent too much muck going in.
Then I make the cuts with a thin disc.
I used a couple of bits of angle clamped together to keep the tubes aligned while I put down a tack or 3. Then removed angle and fully weld.
Attachment 59572
I started making up the brackets to locate the axle on the original Morris leaf springs
Attachment 59573
After cutting the bit of old box section I offered it up to the axle,........whoops! Too big.
In fact, the Mgb axle is same diameter as rattle can, not tin of tomatoes. It's all highly technical.
Started to make another one with another bit of box, but ran out of time.
Also today been putting unwanted bits for sale in an attempt to keep the working area tidy.
Bloody hell really motoring on there. Looks all good and great read. Nice!
I was thinking the same as Gary, good to see you cracking on Ian I'm rained off today so I've had to do house jobs instead, so it's nice to have a bit of hot rod progress to look at mate.[emoji106]
I like the way you always respond to build threads and give us all some encouragement, thanks Tim.
I built my first 2 rods outside in the elements, it's nice to have the luxury of a garage now, even if I only have a few minutes to spare I can usually do something, which helps to keep moving the build forward, and aids me in maintaining my mojo.
Ha ha, it's helped me over the years, having forum encouragment mate.
Must be nice to be able to leave stuff around the car without having to pack it all away each time you're done for the day Ian.
