8 Attachment(s)
How To Add Images To A Post Using the NSRA Image Tool
As promised here is a simple run through of how to insert images through the insert image option included in the NSRA's posting dialog box.
Firstly make sure you go to your settings and make sure your forum settings are correct. To Access you forum settings, go to the top of the page under 'Forum Action' then 'General Settings'.
Attachment 23158
Scroll right down to the bottom of this page and select the "Enhanced Interface - Full WYSIWYG Editing" under "Miscellaneous options". Make sure you click the save button.
Attachment 23159
Next go to the relevant section that you wish to start a new post in and click the red button at the top of the page ‘+ Post New Thread’ or if replying to a thread click the red button at ‘+ Reply To Thread’.
Attachment 23160
Now you've done that select the insert image icon at the top of the text dialog box. The one with the little tree on it. Attaching the images doesn't allow you to increase the size of the image.
Attachment 23162
You will get another dialog box which asks you to insert image. This has two tabs at the top one for from computer and the other from html. Select computer and then at the bottom click the red 'Select files' button.
Attachment 23163
Simply find the image you want to upload from your computer and click the open on the bottom right.
Attachment 23164
You should now have a small image of the picture you selected in the text dialog box.
Attachment 23165
Double click the image and another dialog box comes up for 'Image Settings'. Pick the size you require on the second row down and hit ok.
Attachment 23166
The image should now appear larger in the text box. Finish off the post and then either click the 'Submit New Thread' button or the 'Submit Reply''/Submit Quick Reply' button.
