Custom built engines & driveline parts / best prices
Fastco Automotive Products LLC USA
Custom built dyno tested 100% turn key roller cam'd engines...
*All engines are custom hyd roller cam'd with Morel USA hyd roller lifters.
Chevy 383cid / 450+ BHP
Street & strip engine.
Chevy 383cid/450+ BHP roller engine.
Ford 351C/408 cid / 465+ BHP
World wide suppliers of custom built American performance engines 30 years in business . We deliver the highest quality & BHP and show dressed engines mild to wild @ the best prices bar none.
All engines are TRUE TURN KEY air filter to oil pan, pulleys to flex plates ... nothing else to buy .. remove from crate & load & lite & enjoy!
Engines are dyno tested & tuned & DVD video of dyno test supplied with each engine along with computer printout of dyno test.
***Here's a video of dyno test on Chevy 355cid dyno'd June 19/09
Chevy 355cid on the dyno 350 BHP
***UK based warranty & installation of all of our engines is avalable e-mail for details.
__________________________________________________ _____
*We have over shipped over *300 engines to the UK & Europe e-mail us for customer refferances and speak directly to our customers in regards to our quality & service & pricing.
__________________________________________________ ______
Our entry level HOT ROD engine:
Chevy 355cid DYNO TESTED & TUNED ROLLER CAM'D engine @ 360+BHP complete show dressed turn key prrce $5140.00 USD landed UK ALL FEES
*OUR NEW RELEASED Chevy " Warhammer" series street & strip engines. These are targeted for those who need serious BHP & torque for street & drag race'n on the weekends..
our 355cid engine @ 360+BHP 365 ft lbs torque & our Chevy 383cid 450+BHP 460+ ft lbs torque.
These engines come complete with SFI tag'd flexplate & Mr G flexplate & T/Q bolt kits .
100% TURN KEY & DYNO TESTED PACKAGES PRICED @ *$5140.00 USD
LANDED UK ALL FEES.
We also supply all lines of engines parts , heads , blocks , cranks & kits & Cams & kits , pistons , intakes , ignition systems, headers ect ..@ best prices out there
We will beat any mail order parts suppliers price on any hardcore internal engine parts & engine kits... both sides the pond.
E-mail us for a quote on parts you need & compare our prices to the BIG boys prices.
E-mail Daryl @ fastcoauto@aol.com
Balanced engine crankshaft kits.... @ wholesale prices .... lowest prices out there.
__________________________________________________ _____________________________
Want to build your own custom hot rod engine.... ?
Our Chevy 355cid custom complete engine kit... is most complete kit out there @ the lowest price bar none!
***For the do it yourself Hot Rodder we supply complete engine kits fully machined & ready to assemble.
: eg Chevy 355/ 300 to 350 BHP kit. Blocks are 100% machined 2 piece rear seal .030 &.040 overbore . CL-77 cam bearings & brass frosts loaded .
Crank kit inc new crank CNC machined steel, (Hines balanced crank assembly with balance card) New PRW 8" damper, rods E/W Stage 1 ARP bolts, pistons K-B flat top, rings P/C USA moly , CL-77 main & rod brg. sets , performance hyd cam any grind , hyd lifters,Rollmaster true roller chain set ,Mellling HV 55 oil pump HD pump drive,New chome oil pan 5qt & pick up.
Heads Engine Works USA 2.02 & 1.60 SS valves full CNC machined , stelite seats for unleaeded fuel, Comp V/T , bronze guides loaded. PRW forged roller tip rockers. E/W 4130 forged push rods.
Intake P&P air gap high rise dual plane , carb new Holley 600 or Ed's carb air filter custom 14" KN style as in photos above ,fuel pump E/W chrome 80 GPH , Ignition new Revolution HEI , polished , 53,000 volt coil , Mega Fire 8.5 mm custom wires , Taylor looms NGK plugs ,water pump new E/W USA , pulleys new alum custom , altenator custom 100 amp chrome , custom chrome brackets,belt Dayco cog'd, starter Dura-Last USA , new flex plate with new Mr'G bolts, Water stat chrome, Mr.G thermostat 180F
Cover rocker & timing are chrome .. alum cover avaliable. we supply all hardware all stainless steel. 3 cans VHT paint your choice colour,oil filter & oil & break in lube supplied
This is a complete balanced engine kit with nothing else to buy.
Build it... lite it... & drive it.
*** Price 1650 GBP
We can also supply complete CNC machined blocks ready to assemble... prices start @ 580 GBP / Chevy 350 block.
E-mail fastcoauto@aol.com Attention: Daryl
Visit us @ WWW.FASTCOAUTO.COM
Phone 1-716-471-4146
Email us for a quote on your hot rod engine Chevy / Ford / Mopar/ Pontiac / Olds / Buick / AMC.... we build'em all.
Best regards Daryl Elliott / owner Fastco Automotive USA
*WARNING...
In order to avoid any breathing difficulties during high G-Force acceleration with these engines , female passengers are advised to remove all tight fitting garments.
