Page 105 of 118 FirstFirst ... 55595103104105106107115 ... LastLast
Results 2,081 to 2,100 of 2355
Thread: News on my pop (2)
  1. #2081
    Stripping stuff off to get modified or out of the way !Name:  20250103_143707.jpeg
Size:  53.9 KBName:  20250103_144410.jpeg
Size:  62.3 KBName:  20250104_154601.jpeg
Size:  82.6 KBName:  20250104_160816.jpeg
  2. #2082
    Ali welding needed? Great fun, once you get the hang of it, if you've got the gear to do it!
  3. #2083
    No gear here, i can tig as we had it in work, but the expense of gas and another machine i'll have it done for me !
  4. #2084
    Some more service parts arrived Name:  20250106_161248.jpeg
  5. #2085
    Rose joints fitted with fresh boots. I remembered where Brizey said to get them. And the cage is out after cutting and using a connector on a brace. Hate welding in a trimmed car !Name:  20250110_145820.jpeg
Size:  69.0 KBName:  20250110_155537.jpeg
Size:  33.7 KBName:  20250110_164707.jpeg
  6. #2086
    Went too turn car round... but the starter packed up. Managed too source another spare, changed it and heres the rusty roof !!Name:  20250112_161009.jpeg
Size:  72.7 KBName:  20250112_161015.jpeg
Size:  60.0 KBName:  20250113_145718.jpeg
Size:  56.9 KBName:  20250113_153543.jpeg
  7. #2087
    The dreaded roof joint,the bane of most Pop owners.
    They look (or one of them certainly does) look like the better of the "all talk" starters.
    Hitachi ? Even when one of those fail it's tempting to add an 'S' to the beginning.
    Edit: just thought,it could be the original GM starter to that engine.
  8. #2088
    Original GM scruffy one and new Remy. Although it worked it's not as heavy duty as the original
  9. #2089
    Headliner out.. time too fix the rust Name:  20250115_155534.jpeg
Size:  67.9 KBName:  20250115_160758.jpeg
Size:  50.1 KBName:  20250115_160730.jpeg
  10. #2090
    I'm so glad I had mine media blasted inside & out. Mine is painted the same on the inside as it is on the outside so hopefully rust won't ever rear it's head in my lifetime.
  11. #2091
    Yeah bit of a slip up there with mine as it looked good at the time and cost was holding me back !
  12. #2092
    Neil Young said Rust Never Sleeps. Sorry about that, don't let that thought keep you awake at night. The Rocking in a free world might though!
  13. #2093
    I'll try throwing a few rocks at it Chris !!
  14. #2094
    Talking of Rocks ...the new starter turned up ..Name:  20250116_154824.jpeg
  15. #2095
    On the left ..correct 11t 1.7Kv truck starter.. on the right 9t 1.3Kv car starter. It sounded good turning over ! And the crap paint/rust treatment/rust being cleaned off !Name:  20250117_142212.jpeg
Size:  72.5 KBName:  20250117_161339.jpeg
  16. #2096
    Good to see you boys crackin on in the winter months
  17. #2097
    Well the ''progress'' has come too an abrupt stop the drivers side which has no rust marks on the roof has major rust on the inside. The yellow marks indicates no steel and a few other bits too.
    So a new plan on replacement will be formulated. There was some pics in the gallery where someone had cut it out and replaced it. Does anyone have them ? Name:  20250118_162419.jpeg
Size:  51.3 KBName:  20250118_162414.jpeg
Size:  71.9 KBName:  20250118_181629.jpeg
  18. #2098
    Booger! No steel? Ie holes? What are the repair options? I suppose the question has to be how long does it have to last.
    I'd have thought recreating gutter sections could be a challenge if that was to be required.
  19. #2099
    No point in looking or thinking about it. Might not be the best but at least it's bye bye rust !Name:  20250119_144904.jpeg
Size:  61.1 KBName:  20250119_150955.jpeg
Size:  35.8 KBName:  20250119_152321.jpeg
Size:  61.7 KBName:  20250119_161703.jpeg
Size:  74.5 KBName:  20250119_164353.jpeg
  20. #2100
    OUCH !! John,but while the paints in the gun for the other bits ,best time to tackle it
