Page 110 of 110 FirstFirst ... 1060100108109110
Results 2,181 to 2,200 of 2200
Thread: News on my pop (2)
  1. #2181
    My fan is completely shrouded Ian, no flaps or anything. It's a Mk2 Jag rad recored with a 4 core centre. No problems at idle or at speed.
  2. #2182
    Blackpop i know i should have been paying attention along the the line, but what engine you running? I ve got a mk2 rad sitting in my garage, whete did you get it recored? And sorry to hijack post.
    Gary
    Small block 350 Chevy at last! Yep shoulda done it sooner.
  3. #2183
    I'm running a 350 small block Chevy.
    I got it re-cored by GT radiators in Sunbury.
  4. #2184
  5. #2185
    I’ll Have a look at shrouding mine when the rad comes out soon,hopefully make the fan more effective in traffic jams on a hot day (yes it is the biggest Spal sucker) ,only need a small percentage increase in efficiency here,it needs the rad cap height raising too, like Johns is ,as it causing a slightly short coolant level scenario.
  6. #2186
    Dropped in place yesterday to check fit
    Now waiting on some Mikalor clips too fit hoses. Then the 2 side plates can be tightened. These help keeping the air from spilling round the sides at speed Name:  20250216_142608.jpeg
  7. #2187
    One of collin reays radiators in my old gasser pop. 377 sbc. Over 550bhp. Now ventilation never got hot. Name:  IMG-20210520-WA0000.jpeg
Size:  64.7 KBName:  FB_IMG_1692103650481.jpeg
    Sent from my SM-G990B using NSRA mobile app
  8. #2188
    Various painting and sanding jobs going on ... rub ..paint...rub ..paint ..bah
  9. #2189
    Going for a more 'green' green now john?
  10. #2190
    Just happens to be wot i had in the cupboards
  11. #2191
    great to see the updates
  12. #2192
    Thanks at least with the warmer weather i can get stuff done outside ..more primer going on Name:  20250305_161031.jpeg
Size:  84.4 KBName:  20250305_161025.jpeg
Size:  75.0 KBName:  20250305_161019.jpeg
  13. #2193
    Plenty of sanding going on ...and a frame repairName:  20250307_154218.jpeg
Size:  38.0 KBName:  20250307_163534.jpeg
Size:  46.4 KBName:  20250307_160031.jpeg
  14. #2194
    Chasing a starter fault. Rewire whole circuit too eliminate a poorly wire. And got window frames in primer.
Size:  45.1 KBName:  20250312_161601.jpeg
Size:  68.3 KBName:  20250312_153358.jpeg
  15. #2195
    The crank wire? I see Chevy purple. They're rather heavier gauge than one might imagine. Caught me out when I fitted a nss that had been omitted by previous owner. I just used something I had lying around, chosen on colour. Worked fine, but then had intermittent fault which had me replacing the starter (having tested the wire, 12v, OK!), unnecessarily as it turns out. When the wire subsequently died it was easier to identify (continuity), I then realised my error! Gggrrr.
  16. #2196
    I had continuity, it was resistance that showed up it was quite right, after 20 years of cranking i suppose it had had enough !
  17. #2197
    Ahh, that's it, the wire went blind..... oh, you said cranking....
  18. #2198
    Load to the solenoid ... cranking is taken care off by the main battery wire ?
  19. #2199
    Light duties for a bit so it was sticking labels on stuff so i can find them and finish off window frames Name:  20250315_160431.jpeg
Size:  70.2 KBName:  20250315_160820.jpeg
Size:  71.4 KBName:  20250315_160507.jpeg
Size:  56.5 KBName:  20250315_160445.jpeg
  20. #2200
    Bumbling a long doing little jobs ..Name:  20250316_160736.jpeg
Size:  15.8 KBName:  20250316_161828.jpeg
Size:  52.4 KBName:  20250316_162200.jpeg
Size:  14.3 KBName:  20250316_162651.jpeg
