Page 103 of 117 FirstFirst ... 35393101102103104105113 ... LastLast
Results 2,041 to 2,060 of 2336
Thread: News on my pop (2)
  1. #2041
    Glyn I'm in the same boat, plenty of house jobs done, so nearly there on starting !
  2. #2042
    Deffo would appreciate another live thread, it's been lonely here since Mark finished Phil's Pop
  3. #2043
    Same here, nothing exciting,a bit of maintenance on all three needed, just putting it off for now.
  4. #2044
    Had to service mine the other day! 12,000 miles and the fanbelt needed tightening a bit.
  5. #2045
    Excellent Mark
  6. #2046
    NSRA member Asbo's Avatar
    Apr 2006
    Still plodding away here i will post an update some point
  7. #2047
    About time something was winging it's way on too here !Name:  20241129_204242.jpeg
Size:  121.5 KBName:  20241129_204353.jpeg
Size:  74.3 KBName:  20241129_204519.jpeg
Size:  64.7 KBName:  20241129_204639.jpeg
Size:  100.4 KBName:  20241129_204719.jpeg
Size:  42.0 KBName:  20241129_204743.jpeg
Size:  56.0 KBName:  20241129_204823.jpeg
  8. #2048
    Wanted the rear end lower too put some camber back in the axle. So chopping the wings higher was decided upon. Neat trick with a bit of wood some velcro and a bit of abranet
  9. #2049
    Looks good John, nice trick to get the form even.
    Got to ask, would it have been stronger to use some of that fiberglass reinforced filler to avoid cracks if it's stressed , sorry.
    I don't even know if you can still get it,or if there is anything better nowadays.
    Much harder to form to shape though.
  10. #2050
    I tried it but it wouldn't shape at all, it's about 3mm thick tops, so it gets left a while too fully cure while i get on with other bits !
  11. #2051
    Yeah,as hard as fiberglass i suppose,certanly wouldn't be able to use the abranet former on it.
  12. #2052
    Bit more done. This time flip front need a split and a star ground out. I also added a bit so i could shift a grill trim hole lower
  13. #2053
    if you mix the fibreglass filler 50/50 with normal filler you get the strength and it's easy to sand.
    Thats one too try !
  15. #2055
    Moving on i needed some return flanges on the flip front wings. I m not one for lying under cars but i got them stuck in the right place !Name:  20241130_150800.jpeg
Size:  59.9 KBName:  20241201_141944.jpeg
Size:  59.9 KBName:  20241201_141934.jpeg
Size:  50.7 KBName:  20241201_152619.jpeg
Size:  35.4 KBName:  20241201_161831.jpeg
Size:  80.5 KBName:  20241201_161842.jpeg
  16. #2056
    Good fix’s and improvements John,are you planning to repaint the whole car or just the repaired panels.
  17. #2057
    Getting there John
  18. #2058
    Thanks Martin. Ian it's a repaint too get other bits fixed. You'll see as it progresses
  19. #2059
    Overhead fiberglassing. One of the finer things in life! I stupidly glassed in a cowl vent in a fiberglass 32 Ford body. I think I had more resin on me than on the job!
  20. #2060
    It's not too bad as i can 'flip the front' to do the rest ...it's the 'glass stuck in my hands that cheese me off !
