Page 106 of 109 FirstFirst ... 65696104105106107108 ... LastLast
Results 2,101 to 2,120 of 2171
Thread: News on my pop (2)
  1. #2101
    It's only metal Ian, when the paint goes on it's a different ball game
  2. #2102
    Std place for rotting out behind the drivers B post - not sure why?? More unusual at the end of the gutter though.
    I've learnt with rust now to be a bit savage with how much metal you replace, no point in welding to thin/frilly metal.
    Good luck with the gutters.
  3. #2103
    Cheers Mark. I'm sure there's a transition there that causes the issue ?
  4. #2104
    No the gutter joint is at the front of the door at the top bend. I guess the spot welds and body movement is bigger there allowing water to get under the gutter joint.
  5. #2105
    Yeah i guess your right as the driver side shows that. Better day on it today ... if you call cutting chunks out of it !!Name:  20250121_142140.jpeg
Size:  52.8 KBName:  20250121_144851.jpeg
Size:  55.9 KBName:  20250121_151848.jpeg
Size:  65.8 KBName:  20250121_162659.jpeg
Size:  45.0 KBName:  20250121_164128.jpeg
  6. #2106
    No going back now!! I see the Rock Auto packaging came in handy!
  7. #2107
    i feel your pain with the gutters, i did just that both sides on my anglia estate gasser
    I've upgraded to aldi bran flakes ..bit more flexability in the cardboard !
    Neil it'll be worth it in the end ..when ever that is !
  9. #2109
    Cut out .. bash tin... weld ..repeat ...Name:  20250122_145030.jpeg
Size:  70.1 KBName:  20250122_154715.jpeg
Size:  70.7 KBName:  20250122_162948.jpeg
Size:  90.0 KBName:  20250122_164349.jpeg
  10. #2110
    How are you planning on reattaching the gutters John?
  11. #2111
    Tacking on from underneath there more or less at 45° to the outer edge so hopefully it will do and a skim of sikaflex or filler depending on how it looks
  12. #2112
    Cut .. Copy .. Paste .. leadwork will be cut out ... gutter looks ok this side Name:  20250124_144824.jpeg
Size:  90.6 KBName:  20250124_155436.jpeg
Size:  73.6 KBName:  20250124_164652.jpeg
  13. #2113
    When will it end................
  14. #2114
    With John in the gutter....
    Another post wasted with a whimsical effort that's not that funny,not many left now to my 6,666 deadline
  15. #2115
    ....... i still got the other side too do
  16. #2116
    Needs doing John and your making a cracking job of it and giving everyone who's got that to do a full tutorial. Well done mate and the other side will seem easier I'm sure.
  17. #2117
    Thanks Tim
  18. #2118
    not wanting to teach you to suck eggs or anything but i'd lower the wire speed or increase the voltage. either way will give more penetration and a smaller weld to grind back.
    So more penetration =less grinding,that makes sense Neil
  20. #2120
    I have plenty of flap discs. But your right i'll try lower wire speed but i'm really struggling to get anything like a proper weld without putting a load of heat in. Todays progress at least the ropey lead seam overlap has gone !Name:  20250125_151134.jpeg
Size:  39.1 KBName:  20250125_154619.jpeg
Size:  48.5 KBName:  20250125_163703.jpeg
