Page 107 of 118 FirstFirst ... 75797105106107108109117 ... LastLast
Results 2,121 to 2,140 of 2347
Thread: News on my pop (2)
  1. #2121
    yes don't lower both. just the wire speed. the big build up of weld you have to grind down is due to too much wire. scott my steel fabricator freind told me weld as hot as you can without blowing holes and that'll give you good penetration. a big weld sticking up means either too much wire or not enough heat. with sheetmetal you can't really make long runs of weld or you'll get distortion as you know. so even if you spot spot spot etc continuously to get a run without blowing through at least you'll get flatter welds that go right through.
    Cheers Neil
  3. #2123
    You were right Neil ...dropped it down quite a bit but still had decent penetration ..ooeerrr ...
  4. #2124
    cool. the extra wire now stays on the spool and not as grinding dust on the floor along with the grinding discs you'll save too.
    NSRA member Acker's Avatar
    Jul 2011
    Great tip for the non professionals out there welding in the garages
    But not good for the grinding disc sellers
    I tend to 'pulse' weld now, weld for 1 second, stop for 1 second, weld for one second etc. Keeps heat lower and you don't go off the line.
  7. #2127
    yep, that's what i said.... sort of. spot, spot, spot, etc lol. on sheetmetal it works well.
    Spot..move an inch...spot ...etc..leave cool...nightmare welding overhead... mask earplugs welding helmet ..crouched at 45° won't be doing that again .... oh hang on
  9. #2129
    Working out well! If the car were jacked up one side you should be able to get into it more easily. Wheels on ramps or blocks or similar to try to not put any twisting forces onto the frame / body. Got to be comfortable when welding!
  10. #2130
    Thanks Chris, i need a better plan for the other side, at least i have all the tools out !
  11. #2131
    Coming on well John, play's havoc with the knees doesn't it
  12. #2132
    Anything from the neck down Tim !
  13. #2133
    When we did my roof - god it was 30 years ago!!! we just gas welded the entire gutter to the roof on the top side so the open seam became one with the roof. The beauty of gas was any rust just melted into new steel - seems to have worked as it's rust free still
  14. #2134
    i bet you was all posh and used real welding rods not coat hangers too mark?
    Afternoon on it !Name:  20250128_154121.jpeg
Size:  40.6 KBName:  20250130_151758.jpeg
Size:  69.2 KBName:  20250130_165719.jpeg
  16. #2136
    Always seems to go quicker in the second half. Or maybe it's just all downhill? Don't grind to a halt!
  17. #2137
    Thats mostly because all the tools are pulled out ready Chris !
  18. #2138
    Tidy job John.
  19. #2139
    Cheers Tim just the rain gutter to go
Size:  52.1 KBName:  20250131_142758.jpeg
Size:  55.2 KBName:  20250131_154531.jpeg
Size:  58.4 KBName:  20250131_163757.jpeg
  20. #2140
    And it's on. Wasn't as easy as the otherside but it's done ....put the welder away John !!Name:  20250201_142940.jpeg
Size:  71.2 KBName:  20250201_142952.jpeg
Size:  75.4 KBName:  20250201_143806.jpeg
Size:  48.8 KBName:  20250201_150520.jpeg
Size:  43.7 KBName:  20250201_164434.jpeg
Size:  45.4 KBName:  20250201_165240.jpeg
