Page 108 of 117 FirstFirst ... 85898106107108109110 ... LastLast
Results 2,141 to 2,160 of 2336
Thread: News on my pop (2)
  1. #2141
    NSRA member BadAC's Avatar
    Feb 2022
    John
    Thats looking good, plenty of grinding and smoothing to come. Be worth it though.
    Keeps ya busy.
    Gary
  2. #2142
    Onwards & upwards
    Sent from my SM-G770F using NSRA mobile app
  3. #2143
    What the blue gloop called? I recall Blackpop using it and saying its good. Where does it come from and what do you do with it once it's on there? Cheers.
  4. #2144
    Bilt Hamber Hydrate 80 converts any rust to a protected finish also any bare steel. Epoxy on the inside and outside then finish outside as normal. I've tried too keep grinding too a minimum too save thinning the steel
  5. #2145
    Cool, thanks. I've got something that'll need something like that in a few spots. 2 coatx required it seems. What's the coverage like? The small pots are 500ml.
  6. #2146
    It's very thin almost like water. The epoxy is a bit thicker tho
  7. #2147
    Plenty going on ...Name:  20250202_153436.jpeg
Size:  86.2 KBName:  20250202_162552.jpeg
Size:  63.4 KBName:  20250202_162604.jpeg
  8. #2148
    Looks busy John, coming on well mate.
  9. #2149
    Confused now! What's the black stuff? I'm guessing it's the blue stuff doing its thing, but you did mention epoxy, hence my confusion! And the still blue bit in the gutter area makes me think the black has been applied arohnd it? There was mention of seam sealer or filler in the joint gutter seam (which is blue) which again I'm guessing might have something to do with it? Sorry to be an inquisitive pita!
  10. #2150
    The blue stuff has gone black too show it's worked. Epoxy paint goes over the top. Seam sealer or probably sikaflex will be pushed down in too the channel and smoothed too make sure no water sits in there as it'll cause rust ! I cant get in there too smooth it off as it's quite a deep narrow channel now
  11. #2151
    Ah ha! Thanks!
  12. #2152
    Needs painting now ..full strip out !Name:  20250203_150249.jpeg
Size:  57.9 KBName:  20250203_153024.jpeg
  13. #2153
    NSRA member Glyn's Avatar
    Aug 2005
    Really cracking on John, excellent work!
    I've been cracking on with mine. Made a new fuel tank to include a in tank pump. I was using the original tank with a set of pumps and swirl pot n the boot. The high pressure pump I had was really noisy and I was getting fed up with the whine! Fired the car up and ran well at the weekend. I've got a few more jobs to be cracking on with before the season starts.
    Zetec powered pop ON THE ROAD!!!
  14. #2154
    Excellent news Glyn. Keeps the pump cooler too. Always plenty to do with these pops !!
  15. #2155
    Sounds like a very worthwhile improvement Glyn,
  16. #2156
    Aug 2005
    Yep always lots to do. I've worked out the capacity of the tank should be approx. 9 gallons now rather than the 5 gallon of the old tank. Suppose the real test will be whether I can get to the fun run on a single tank.... maybe!
  17. #2157
    Funny enough i worked mine out to get too Evesham from Swansea, by then i needed to get out and stretch my legs and have a cuppa, came out at 8.8 gallons with a bit in reserve !
  18. #2158
    Other capacities restrict our travel to about 1 1/2 hours tops! Might as well fill up at the same time as emptying out, but not literally though!
  19. #2159
    Aug 2005
    Are you finally revealing the mystery of who fills up the water buckets at petrol stations Chris?
  20. #2160
    Quote Originally Posted by Glyn View Post
    It's a dirty job, but someone's got to do it!
