Page 109 of 112 FirstFirst ... 95999107108109110111 ... LastLast
Results 2,161 to 2,180 of 2235
Thread: News on my pop (2)
  1. #2161
  2. #2162
    Got the garage warmed up and got the epoxy rollered and brushed into the gutters Name:  20250205_162217.jpeg
Size:  58.6 KBName:  20250205_162237.jpeg
Size:  45.1 KBName:  20250205_162229.jpeg
  3. #2163
    the epoxy looks like a stock pop colour, lol.
    Oh i've tried that too ...thats ral 6011 if i remeber right. Langy always said get your primers tinted too match the spray job then stone chips dont show through
  5. #2165
    he was a smart guy, sorely missed
    Too true Neil.
    Looking good John good luck with the top coat(s).
  7. #2167
    Cold temps no good for getting a second coat of epoxy on. So a bit of sheathing on the overhead wires and a fresh new rad from Collin Reay at creative aluminium fabrications so i can access the rad cap through the bonnet and a decent coat of paint on the manifolds from Maldon shotblasters ... just got too shift the flu now Name:  20250208_154941.jpeg
Size:  47.8 KBName:  20250208_161405.jpeg
Size:  77.4 KBName:  20250210_114249.jpeg
Size:  87.2 KBName:  20250210_114233.jpeg
Size:  82.1 KBName:  20250210_113341.jpeg
Size:  49.2 KBName:  20250210_113347.jpeg
  8. #2168
    NSRA member BadAC's Avatar
    Feb 2022
    Very nice work. Great looking rad.
    Getting there.
  9. #2169
    Nice looking rad John.
  10. #2170
    Collin did the original rad and run it for 7 years with no issue cooling the LS so no point in going anywhere else for another one !
  11. #2171
    Aye, why would you?
  12. #2172
    Exhaust manifolds fitted back on and new ignition switch Name:  20250214_155351.jpeg
Size:  61.2 KBName:  20250214_155346.jpeg
Size:  72.7 KBName:  20250214_155358.jpeg
  13. #2173
    Rad tested fitted. Fan mount plate adjusted to suit and fan added with some inverted rivnuts. Coat of black on the front !
Size:  85.4 KBName:  20250215_150936.jpeg
Size:  40.7 KBName:  20250215_150940.jpeg
Size:  66.2 KBName:  20250215_155819.jpeg
Size:  76.9 KBName:  20250215_161132.jpeg
Size:  80.4 KBName:  20250215_161620.jpeg
Size:  84.5 KBName:  20250215_164729.jpeg
  14. #2174
    Rivets used kinda backwards.. integral spacer or crush sleeve... neat.
  15. #2175
    ' rivnuts' Location posts and no chance of bolts hitting rad
  16. #2176
    Autocorrect can be your worst enema! Rivets??? Ffs!
  17. #2177
    Colin hates it when one of his radiators are painted,but has to be done, seeing anything other than black through a grille should be illegal
  18. #2178
    Ian i found that when the stainless bar grills i made for the nose section on the flip front were viewed from the front they were almost unnoticeable, i've only painted the front i too look them shiney !
  19. #2179
    I guess I didn't type that how I meant it,dark or black behind grille bars is what should have put,my grille 'V' bars are now stainless originals now instead of being black since 1981.
    Yeah,I only painted the front of my radiator.
    Got to ask you about your fan shroud John.
    Did you have it on your last radiator.
    Have you ran it with and without before.
    If so did it improve stationary idling in traffic temperature's.
    How much did it affect high speed cooling.(I noticed the rubber flap for this) My experience of Colin's rads is that they seem to have excess cooling capacity at high speed that can be sacrificed.
    It's seems like there's not much gap behind it,is it still effective, obviously we don't have much room in pops for bigger gaps.
    Seems like more questions than I expected to type
  20. #2180
    It's the same set up with the rad cap moved back so i can fill from the bonnet, not flip the front, in years too come it might be more useful
    The LS runs hotter than most other chevys, 210f they are quite happy with, and the fan has always been adequate for it, luck than judgement
    The flap does work too a fashion, i've opted for a slightly lighter one to see if it makes any difference
