Page 56 of 109 FirstFirst ... 646545556575866106 ... LastLast
Results 1,101 to 1,120 of 2166
Thread: News on my pop (2)
  1. #1101
    NSRA member chris's Avatar
    Jan 2005
    Took out the nasty rubber arial today and filled the hole,whacked some primer on it just to protect it...
    Better aerodynamics John
  2. #1102
    3.9 is for next year. just good old fashioned 3.5 for this
  3. #1103
    Jan 2005
    Been off work this week due to it being quiet and spent alot of time messing in the garage,getting back in the groove.
    Cut a new bracket for the battery today,had the kids helping with filing/painting,took an age to cut the diamond shapes (3mm plate!) but wanted something different to just holes.
    Gonna whack some carpet in the boot soon too.Extra weight but will tidy it up no end.
  4. #1104
    Guest 53pop's Avatar
    Mar 2009
    nice to see you back on it and the bracket looks good keep it going mate will soon be done
  5. #1105
    Yep nice work chris, no news on mine other than it did billing and back witout a hiccup, good mpg too busy with the teardrop at the mo !
  6. #1106
    NSRA member Rover V8's Avatar
    Hi Chris,
    Bracket looks good, glad your getting back to it, keep it up mate
    Mikes V8 Pop build
    IT'S ALL GOOD IN THE HOOD
  7. #1107
    Worth the time and effort though Chris, looks great mate.
  8. #1108
    Jan 2005
    Thankyou.
  9. #1109
    Quote Originally Posted by chris View Post
    Lightened, for some bracket racing eh Chris
  10. #1110
    Pop top tip
    Following on from my last 'Top Pop tip',of greasing the door latch behind the door panel,which has been of some benefit to at least Alex (my53anglia)
    I can bring you another Top Pop tip,born out of 'numptieness' on my part
    I have had a spot of water leaking in through the top of the boot since i put my pop on the road in 1980,and i have only just found out the reason,after a short investigation ,i found that the water was getting past the original screws that hold the boot catch to the drainage channel of the boot.
    So, some new pan head pins and some silicone to seal under the heads should now see the end of that silly problem.
    Took me 30 years ,but i got there
  11. #1111
    Jan 2005
    Well done Ian! 30 years eh...
    Water is a right ******* is'nt it,gets in everywhere!
    I had a small leak in my boot,only for the 4 years i've had it,and thought it was due to the poorly fitting ('glass) bootlid.
    Yesterday i took off the Jag filler cap and there is a hole in the bottom of the recessed panel...filled it and im hoping that has sorted mine also.
    My Minor also leaks like crazy around the front 'screen,NO amount of silicone can sort it...oh well,i'll keep wearing my wellies!
  12. #1112
    Guest my53anglia's Avatar
    Oct 2008
    Quote Originally Posted by Captain Scarlet View Post
    It sounds pretty daft as I have had my car for 34 years and always thought the doors were just heavy. As I had to change my windows anyway I took the time to do as Ian suggested. Blaaadddy Hell What a difference. No more mega slamming to get the doors to close.
  13. #1113
    Me and Alex are lifers Chris
    Hope your leak is fixed Chris,and glad the grease worked for you Alex,its really satisfying to get a result on the smallest problems sometimes.
  14. #1114
    All these tips, I hope I can remember them when I get around to the bodywork!
  15. #1115
    Great tips Guys, keep em coming would have missed the boot catch one, cheers Ian, better late than never
    Mikes V8 Pop build
  16. #1116
    Jan 2005
    LOL
    Blew another cherry bomb off me exhaust last night,thats the second time!
    The focus that was up my ass at the time had a bit of a shock lol!
    Saved the bomb too.
  17. #1117
    NSRA member Flamin Black A's Avatar
    Apr 2005
    I blew the valley gasket on the way to the nos nats on saturday.
    Another job to do
  18. #1118
    I guess you will be checking out your crank case breathing too, like Swompy then eh Peter ?
    I have seen them 'balloon' up with very excessive crank case.
    Did you see the link in Swompys thread.
    http://www.nsra.org.uk/newforum/newr...ote=1&p=327223
  19. #1119
    Apr 2005
    I did Ian and I've had advice from Klunk as well. I replaced the gasket before billing and changed the breathing and everything was fine untill I was driving up to the nos nats.
    I think I need to check it again
  20. #1120
    Good luck with the motor Pete, hope it's not too expensive,
    Mikes V8 Pop build
