Results 1 to 3 of 3
Thread: New Chevy 355cid SLAYER engine 380+BHP hyd roller cam'd / dyno tested
    Thumbs up New Chevy 355cid SLAYER engine 380+BHP hyd roller cam'd / dyno tested
    TRADE:
    Chevy 355cid Slayer series engine 100% turn key / dyno tested / fully show dressed
    Fastco Automotive Products USA SBC 355cid/380+BHP "SLAYER" engine
    ENGINE PHOTO ABOVE IS EXACT ENGINE YOU WILL RECIEVE
    Build spec sheet: of our new for 2014 Chevy 355cid / 380+BHP ROLLER CAM'D "SLAYER" series engine.
    Chevy 350 block 1970 to early 80's only.. (Dart & Warhammer blocks aval.) , our blocks are fully CNC machined on state of the art RMC V-20 CNC , oil mods done, bored .030 to .040 over , decked & squared , CL 77 cam bearings loaded , brass frosts loaded, CL-77 main & rod brg loaded.
    * Note all of our blocks are pre 1993 castings and are 1970's era up to mid 1980's and no newer.
    New E/W USA head stud kit is used with all our alum head engines we do not use new bolt kits or old used GM bolts on any engine as most supplier do... used bolts are junk & new bolts do not provide proper torque spec & distort alum heads when torqued & cause heads to crack & head gasket failers.
    Crank is new RPM or EAGLE steel full CNC machined 3.48 stroke/ 500 BHP rated (we do not use old reground stock cranks as some suppliers do) ,
    Rods are new E/W USA Stage II 4130 forged steel / floating pins with cap screw rod bolts/ 500 BHP rated ( we do not use reconditioned stock GM rods in our engines as some suppliers do)
    Pistons K-B hyperutectic or Speed Pro flat top 9.8:1 comp(forged ICON USA pistons aval. add $245.00) , Hastings moly ring set. Damper is new RPM 8" 360 degree marked.
    *** Crank assembly Hines balanced with balance card supplied.
    Cam custom grind COMP CAMS hyd roller .565 lift / 110 CL cam uses stock HEI iron gear no need to worry about worn bronze brass dizzy gear, hydraulic rollers are MOREL USA horizontal guide bar type not cheap vertical bar style, Pushrods are COMP CAMS for perfect rocker arm geometry.
    *BEWARE of flat tappet cam'd engines due to there known cam lobe & lifter failer rates with the use of high pressure valve springs & all oil companies world wide removing needed zinc & phosphate friction modifiers from all oils... this causes rapid cam lobe and lifter wear with high lift performance hyd or solid flat tapprt cams)
    Roller cams will deliver more BHP & torque over a wider range & produce much better MPG over flat tappet cam'd engines. And you never have to worry about worn cam lobes & lifters ever gain... the first thing to ware out in a high performance FLAT TAPPET engine is the cam & lifters.
    Chain set is true roller .250 dia pins by ROLLMASTER with billet gears 9 keyway crank gear & torrington needle thrust bearing plate ,*Gear drive systems by PRW are avalable.... noisey or quite series add $180.00 USD... included install & block mods.
    Engine Works USA roller thrust cam button installed . Timimg cover is alum with thust button pad.
    Oil pan is custom 7qt road race low profile , trap door & baffles , pump Melling HV-55 with ARP drive. oil pump ARP stud mounted.
    Heads are new 2010 design RPC Engine Works USA 200cc runners alum heads , full CNC machined (these heads flat out perform Pro Comp or Patriot or Edelbrock RPM heads on the flow bench and on the dyno we see 30+ BHP gains over other manufactors heads with these new design heads) valves are 2.02 & 1.60 SS valves , dual springs 1.400 dia, moly retainers , 10 degree locks , Viton posi seals , thick wall bronze guides , 7/16 rocker studs , E/W 5/16 guide plates.
    *We can add any other cylinder heads you perfer to this engine... eg: Dart , Edelebrock , AFR , Brodix , RHS ect contact us for prices.
    Rocker are WARHAMMER SS roller rockers 7/16 stud mount
    Intake is Victor Jr type Hurricane high rise or Air Gap dual plane your choice ( polished avaliable/ add $90.00 USD)
    Carb is new "QFT USA SLAYER" series carb 600CFM dual feed, billet meter block ,fully adjustable secondaries , power valve protection , glass float level sites. This carb is QFT new SS series carb & we will be using this new Slayer carb on all our engines as of Nov.17 2011....NO EXTRA CHARGE for this new high tech carb.
    Ignition Revolution HEI polished , 53,000 volt coil , brass terminal cap ,recurved to MAX engine BHP & torque on the dyno , Wires Mega-Fire 8.5 mm custom with Taylor looms , NGK plugs.... we can add ATE 6AL digital ignition amp to ignition system with 2 step rev limiters / dial in type NO PILLS used as with MSD limit RPM from 900 to 9900 RPM @ $269 USD
    Covers are custom alum polished , plain or ball milled or flamed , PCV billet alum , breather KN type, all lines are braided SS with alum collars ,
    Fuel pump BIG END 110 GPH chromed, MrG chrome block plate , ARP fuel pump drive shaft, water pump new (short ot lomg pump) E/W USA,
    Pulleys are custom alum or we can add a COG DRIVE/ GILMER BELT system to your engine adds 90 GBP, Altin 100 amp chrome 1 wire , bracket custom billet alum, belts Dyco cog'd, All hardware is custom SS *(we hate rusty bolts)
    Engine comes with flexplate 153 tooth or 168 tooth your choice , Mr G mount bolts included for flex plate & torque conveter, Starter motor is Dura-Last USA .
    Your engine is dyno tested & tuned by 3 ASE certified tech staff with over 90 years combined expereance in custom engine machining & building & modification & development & racing of all types.
    ***DVD of test & computer printout supplied with engine with all other documents***
    "SLAYER" Chevy 355cid/ 380+BHP roller cam'd engine
    100% true turn key / dyno tested & tuned ....... nothing else to buy.
    PRICE * 3690 GBP landed UK all fees.
    Contact: Daryl fastcoauto@aol.com
    Fastco Automotive sending American HP cross the pond for 18+ years.........
    *Feel free to contact us for a long list of UK customers get there feed back on there Fastco engines quality & our customer service
    *Recent customer comment on his new 355 cid SLAYER engine ....April 10 /2014
    Daryl engine is performing excellent !
    This engine has completely transformed my old FJ40 into a real beast of a truck !! a lot of fun to drive !!!
    Thanks again Daryl for you excellent work !!!
    Cheers Tony
    Call us @ 1-716-471-4146 EST / USA
    Many dress up options avaliable Mod Rod to O'll Skool.....
    Photo of Ians "SLAYER" engine with March Revolver kit loaded into Ians truck
    Chevy 355 cid SLAYER engine with cog drive option added....
    *Looking for a race engine for track or drag?.. ask us about our race engine sponsorship program....
    Fastco Automotive sponors UK Sprint car race teams & Drag race teams.
    Video of Trevors 355 cid 500 BHP Sprint car engine on the dyno click onto photo to see video.
    Thumbs up Mick's L'll monster..our SLAYER 355cid roller engine on the dyno May 19 2014
    TRADE:
    Video of Micks 355cid SLAYER engine on the dyno May 19 2014, with 6AL ignition amp wired made 396 BHP @ 5900 RPM
    Click on photo to view video....
    ​ENJOY MICK....Cheers!
    Thumbs up Pic of Looney's 32 Coupe with our Slayer engine...takes 1st place @ car show.
    Photo of Looney's 32 Coupe with our 355 Slayer engine & our full tricks Stage II 350 trans & custom 10" 2800 stall converter.....
