I've fabricated the brackets and mounted the pump.
Two of us have independently googled for a wiring diagram but with limited success.
This is an electro/hydraulic pump mounted on the inner wing and plumbed to the steering box.
I have a large red wire which is permanently live (70amp fuse).
A large brown wire which is earth.
There are three small wires in a waterproof multi connector.
Blue/white goes to the ignition light terminal on the alternator so the pump only runs when the engine is running.
Black is ignition live.
I am confident that the above is correct.
I can't identify where the brown/white connects...help please.
