Page 3 of 23 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 452
Thread: Widowmaker
  1. #41
    NSRA member fabphil's Avatar
    Mar 2014
    That's a nice looking engine.
    What do you use for polishing?
    You have to get older, but you don't have to grow up!!!
  2. #42
    Great build-up - nice to see proper work going into it to save and improve it.
  3. #43
    You're making a fine job of that. Engine looks stunning.
    Carry on.
  4. #44
    NSRA member West's Avatar
    Nov 2019
    Quote Originally Posted by fabphil View Post
    thank you, i used a bench grinder, with the blue and brown bars,and a couple of different grade mops.
  5. #45
    Nov 2019
    cheers rem,want to make it safe so my boys can cruise with me,also a few tweaks and subtle changes.
    Quote Originally Posted by rem View Post
  6. #46
    Nov 2019
    thanks chap,will do my best..
    Quote Originally Posted by Morris460 View Post
    Carry on.
  7. #47
    Nov 2019
    still loads to show you guys,having to find all my old pics and shrink them
  8. #48
    Nov 2019
Size:  64.9 KBName:  41642418_10214327469074699_4747136071328858112_o.jpg
Size:  68.0 KBName:  41509710_10214324823728567_7649258383907749888_n.jpg
Size:  58.9 KBName:  38424598_10214070967302315_2156477146309066752_n.jpg
Size:  60.6 KBmade these brackets for 4 bar triangulated/transverse leaf spring.
  9. #49
    Nov 2019
Size:  34.2 KBName:  53630604_10215486294804618_6227971461332598784_n.jpg
Size:  29.3 KBName:  54267944_10215480917110179_3905142350384463872_n.jpg
Size:  42.5 KBName:  53365773_10215480917670193_238629203304513536_n.jpg
Size:  53.1 KBdecided it wanted a manual box, as i am on a budget, type 9 box 5 speed is to be used,as we all know these are narrow cars,and not much room with the daimler,so decided to widen 4".
  10. #50
    Nov 2019
Size:  65.1 KBName:  54434033_10215480916510164_1192174052538580992_n.jpg
Size:  46.4 KBName:  54462397_10215480918270208_863215643980201984_n.jpg
Size:  44.9 KBName:  53674790_10215480915030127_8099058407463452672_n.jpg
Size:  45.1 KBName:  FB_IMG_1561458837788.jpg
Size:  60.9 KBi think it gives the front and rear windows better proportions
  11. #51
    Lovely work going on, keep it up.
  12. #52
    Nov 2019
Size:  100.7 KBName:  20190625_204147 (2).jpg
Size:  91.0 KBName:  20190802_190100 (2).jpg
Size:  102.5 KBName:  20190805_161256 (2).jpg
Size:  92.4 KBName:  20190807_161002 (2).jpg
Size:  93.8 KBName:  20190802_204635.jpg
Size:  58.7 KBName:  62076341_10216056771626182_986821620188315648_n.jpg
Size:  36.6 KBName:  20190803_181605.jpg
Size:  47.0 KBrear arches repaired,just need to bead roll around the bottom edge..
  13. #53
    Nov 2019
Size:  47.1 KBName:  49245515_10215043906225180_7970928215784947712_n.jpg
Size:  40.7 KBName:  49745617_10215043908145228_2018706664311488512_n.jpg
Size:  63.3 KBName:  49276812_10215043907745218_8950123095042031616_n.jpg
Size:  52.9 KBo/s/r arch repairs.decided to put a little curve at the bottom,instead of going straight down,small changes make a difference i think..
  14. #54
    Nov 2019
Size:  49.0 KBName:  20190706_151330.jpg
Size:  39.1 KBName:  20190706_143103.jpg
Size:  41.2 KBName:  66840266_10216284154630615_2264481713944002560_n.jpg
Size:  21.3 KBName:  66625629_10216284154390609_3341408750115225600_n.jpg
Size:  30.1 KBName:  20190803_181542.jpg
Size:  50.3 KBmade a new rear panel ,as it wasnt worth widening the oid one,my boy helped again,costs me one pound every time he helps on turn the bead roller handle..shrinker/stretcher came in handy with this one..
  15. #55
    Nov 2019
Size:  100.7 KBName:  20190712_204256 (2).jpg
Size:  70.8 KBName:  20190713_175014.jpg
Size:  38.8 KBName:  20190716_201448.jpg
Size:  25.0 KBwasnt happy with the lower section of the body were it meets the new rear panel,so redid it,much better fit, well happy
  16. #56
    Nov 2019
Size:  65.0 KBName:  58420175_10215771724460181_8785142341661884416_n.jpg
Size:  54.7 KBName:  58802436_10215771724700187_9069509609479208960_n.jpg
Size:  45.7 KBName:  58460584_10215771725820215_2288650177818394624_n.jpg
Size:  54.6 KBName:  58701331_10215771726100222_1270413569099300864_n.jpg
Size:  44.5 KBhad to widen the dash 4" didnt like the ford dash,tried to mirror the scuttle panel,will do for now,but still work in process.
  17. #57
    Nov 2019
Size:  80.4 KBName:  received_367289950608310.jpeg
Size:  66.5 KBredrilled holes for stronger/larger spring perches.
  18. #58
    Nov 2019
Size:  38.9 KBName:  55598883_10215588595762078_6523656947227426816_n.jpg
Size:  46.1 KBName:  55875428_10215588596722102_4457556512805486592_n.jpg
Size:  36.1 KBName:  56178715_10215588596082086_8526373877792636928_n.jpg
Size:  40.0 KBdoors in need of some serious repairs,plenty of old paint,apparently the car was originally grey.
  19. #59
    Nov 2019
Size:  148.7 KBcheeky monkeys.....
  20. #60
    Nov 2019
Size:  44.2 KBName:  20191009_194306.jpg
Size:  48.7 KBName:  20191006_171120.jpg
Size:  63.9 KBback end of 2019 decided to make over the garage,i was fed up of tripping over stuff and working in a dark **** hole,much better..
