Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Door pin removal !
    Door pin removal !
    Should have been a simple tap out job as the doors were off not so long back .... and new stainless pins too... but that didn't happen. So a 45 year old apprentice piece got modified to suit ! Name:  20200707_171818.jpeg
Size:  38.8 KBName:  20200707_171754.jpeg
Size:  37.2 KBName:  20200707_170959.jpeg
Size:  28.2 KBName:  20200707_171618.jpeg
    Sent from my SM-A405FN using NSRA mobile app
    Nice one John, I've still got all my tools I made as well.
    Pop door pins are such fun
    New guest
    Mar 2020
    good idea!
    could be helpful for me in future
    Nice one John
    Mine still has the original pins in it,I have never removed them,no play in them either, hope I don't have to seeing how much they seize in.
    Me and my big mouth ,driver side lower pin appears to have sheared sometime this year,top is fixed but underneath it’s moving,there may be trouble ahead
    Easier to get the top pin out first and work on the door and pillar separate i would think ?
    Holy thread ressurection Batman!!!!!!! Kapowwww it with an air hammer. Got a Bob Drake removal too here (somewhere) if it's any help Ian.
    Thanks John and Chris, I'm going to assess this carefully before I start , can't see how it could have snapped in two,maybe I am mistaken.But if it is in two pieces it may complicate the removal if it's broke at an angle.
    May just take you up on your offer Chris ,or I may make a tool.
    It's also been suggested to drill out the hinge rivets, remove the hinge from the door then bolt the hinge back afterwards.
    Might wait for the weather to go above freezing
    But it's got to be done, it's making the door catch rattle .
    Nov 2018
    It’s making my teeth rattle the few I have. O the broken pin
    Quote Originally Posted by Captain Scarlet View Post
    May just take you up on your offer Chris _smiley:
    Thought to myself I'd not seen it for years so had best instigate a hunt. Found lots of interesting and useful things that I'd forgotten about, and then through the cold mist.....
    ChrisName:  1670772842853.jpeg
    Sent from my SM-G900F using NSRA mobile app
    NSRA member tom.marg's Avatar
    Dec 2014
    Good idea ����
    YouTube - Toms Custom Shop
    https://www.youtube.com/channel/UCro...hD-y5NuJyZAA2Q
    8.43 @ 157 - Rail
    10.37 @ 128 - Doors
    Nov 2018
    I have a similar looking tool but it’s for torsion bar adjustment. Same principle.
    Thanks for looking Chris
    I have done some of those hunts for items and found other things I had either lost or forgotten about.
    Having had a closer look at the hinge,it may have seized and broke in the door part of the hinge a few years ago and has worn the lower section at least.
    Good luck with it lan.
    Thanks Tim, got a few ideas,probably have a look in the new year
    if it was a real bu66er to get out i'd cut through with a 1mm disc. it'd remove some hinge material but nothing a brass/copper shim washer or two wouldn't fix, plus it wouldn't then be steel on steel.
    Another good idea,thanks Neil
    It's good to be prepared,there is an oversize pin available too,or I could brass bush the bottom section with a mini hinge repair kit, almost looking forward to it now.
    Just need to get my lazy ass into that cold garage
    NSRA member nigelh's Avatar
    It was -9 in Bristol on Wednesday night.
    Brrr
    Another good idea,thanks Neil _smiley:
    Today I realised that I'm not as young as I once was
    http://www.bristolhotrods.co.uk
    Nov 2018
    What did the romans ever do for us. Sanitation ect and garages! Not on my street hay pop Tim. You need to put on your electric onesie. Good luck Ian,don’t damage the paint .
