Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 287
Thread: So gonna start rebuild/upgrade
  1. #101
    Lexus V8? Saab9000 turbo?
  2. #102
    Saab it front wheel drive no? And lexus lodsa wiring ECU's etc. I had thought of bmw but again to much electronics. I am jusy an old duffer who likes simple.
    Just spoke to D&A engineering n Manston who do v8's only and a much better deal as well as only 2-4 week turnaround. Helpful fella.
    Small block 350 Chevy at last! Yep shoulda done it sooner.
  3. #103
    Saab 9000 RWD, cranks & rods are good for 500bhp as std. A few small tweaks to induction & turbo and 350bhp is easily achieved.
  4. #104
    well i beg to differ only the 3.5 has the small bore. all others... 3.9,4.0,4.2 and 4.6 use the same 'bigger' bore with different strokes.
    http://www.v8wizard.com/What_are_the...Capacities.php
  5. #105
    Your right Neil I meant bored, 94mm instead of 89 ish. Found a supply of pistons so gotta take block to engineers to make sure 20 thou will clean up bores.
  6. #106
    So after a bit of a bummer with the 3.9 over lump needing a rebuild, also finding that the holley 500 that my boy bought for me was actually a 600. I have decided to sell the engine as a project for someone else to build, sold the carb and manifold.
    Now bought a 4.6 with dizzy conversion which is in great nick, fingers crossed. Going up the northampton on monday to collect.
    Just put springs and beam axle back on the old girl ready to do brakes.
    Fell ar*e over t*t walking backwards over the chassis, ouch.
    Keeping an eye for a carb setup for the 4.6.
    Onwards and upwards.
  7. #107
    the 600 holley would do for the bigger 4.6 engine.
    It's already on way to wales.
  9. #109
    So 3.9 now sold as a big box of bits to a guy with more time than me.
    4.6. Collected and all looks good, stripped off all the bits i don't need like power steering, injection bits.
    Popped over to Neils ( my gasser) to collect disc conversion, all good and ready to stick new discs on and fit. Cheers Neil.
    So now chasing down a carb setup.
    Gary
  10. #110
  11. #111
    Cheers Neil
    Seen those on eblag.
    Dont like the adapted manifolds had one before did not run right.
    Might be onto one at moment just waiting to see.
  12. #112
    Now sorted carb wise.
    Weber 500, edelbrock inlet and nice chrome air filter.
    Just got to pop over to redhill on saturday to collect it.
    All coming together.
    Gary
  13. #113
    Si collected weber etc all good. Carb almost brand new, never fitted. Result.
    Fitted first of the disc brake conversion, doing other one this evening. New bearings and disc, looking good. Cheers Neil for job well done.
    Then away for 3 weeks, hope to come back refreshed and raring to get on.
    Take care guys.
    GaryName:  20240626_110817.jpg
Size:  340.2 KBName:  20240626_111035.jpg
  14. #114
    those new discs look a bit better than the mockup ones gary
    have a great holiday mate.
    Hi ya
    Back down garage after 3 weeks on holiday and then a week having all windows in the replaced and a mega deep clean. Phew!
    So finished fitting both sides of the disc conversion, ckeaned up axle, bit of black 2 pack. Sorted. Spent ages cutting and grinding off old engine and shock mounts, cleaned up area for working out engine mounts.
    Also need to source a dual circuit non servo master cylinder to fit under floor, ideally .75 inch plus. Seen some vw ones look potentials.
    Cheers G
  16. #116
    I'd suggest that you should be looking at a range of masters, eg Wilwood, such that if you need to change the diameter a replacement just bolts straight in. There may be tables somewhere detailing for example vw masters by diameter, application, part number etc, but there might not be!
    I'd also suggest that if you've got 6+ :1 or so pedal ratio, .75 diameter is a bit on the small side as a starting point. 13/16" or maybe 1" is where I'd pin the initial tail on the donkey. You should be able to nail it in one. I did see you said .75 plus.
  17. #117
    Cheers Chris
    Yeah probably right, need to measure up original pedal leverage. Want to use original mounting position and AC pedal, i can mod the bracket to suit fixing as curently a 2 bolt fixing, AC master was 3/4 inch so thought start there. But a bit of reseach to do.
    Gary
  18. #118
    remember disc systems usually have bigger master bore as calipers use a greater volume of fluid.
    Cheers Neil.
    So had a look at pedal set up and this is what ive got.
    A 12.5 inch pedal arm from pedal face centre to bottom pivot. The pivot rund through a bush in the chassis and comes out t'other side with another little arm coming back up which is 2.75 inches this has the master cylinder pushod fitting.
    Now looking at wilwood site pedal ratio calcs, this set is not shown, but using their method I make my ratio about 4.5 to 1, not sure if that is or have I missed something as the pivot and m/c arms are not on one plane.
    Anyone understand physics and fulcrums?????? Argh��
    Heres a pic
  20. #120
    Your sums sound ok to me. Masters require just over an inch, say 1.25, of travel for full stroke. You might be able to shorten the arm some to get a better ratio. How much travel is there before the pedal hits the bulkhead?
    Sent from my SM-A750FN using NSRA mobile app
