Page 20 of 20 FirstFirst ... 10181920
Results 381 to 384 of 384
Thread: Pop Mayday.
  1. #381
    Shifts are fine kev, it's just when lifting the throttle at speed it feels like the gearbox has grabbed the prop momentarily so the UJ's bang hard. It does it at lower speeds sometimes but no-where near as harshly.
    Is the kickdown connected as it's essential to balance pressures internally. Otherwise you only have input from the vacuum regulator.
  2. #382
    Yes kickdown connected and working at wot
  3. #383
    Andys (car sos one, lol) screen surround is now fully painted, quite happy with this.
    close up of the colour;
  4. #384
    Back on Andy's car.
    His drivers door does not line up with the jaws in the B post with the door wedge and forces the door upwards as it closes. This means it needs a good slam to close and misaligns the door.
    You can buy offset wedges - but these have already been fitted but it is not offset enough.........so I made a new one The pen line on the old one is where the wedge needs to be. Standard wedges are in the middle of the bracket.
    This was all going well until I wanted to heat treat it to harden the ally. "Dangly male reproductive spheres". I guess the melting point of ally is quite a bit lower than my Mapp torch output.
    Bumhats. It went a bit wibblepoo.
    As I don't have any tubes of aluminium glue at home I had make a MkII version in steel as I only have steel glue here Blanks cut and starting to shape them.
    And all glued together with the sparkly glue stick.
    This should work nicely - I'll check it works smoothly before painting in case it needs a bit more profiling.
