parts for low budget build 34 truck build for a bet so can you help me out
1 flathead 59 powergen alternator,2 pair of headlamp stands,3 pair of vgc strombergs,4 pair of hinge mirrors,5 window regs,6 door latches
07891409588
what type of headlight stands are you looking for ? if fender less I have a stock original headlight bar for a 30 , I usually cut these up for fender less headlight stands , If thats what your after , I have one , I'm looking for ?60 for that ,,
Probably got a hand full of used early carbs including 97s but good ones don't come super cheap , If I have 2 decent ones they would be sold as cores, impossible to guarantee a used carb thats been sat around. looking for ?140 a carb.. new ones are close to ?400 these days, all parts available to refurbish.
If your interested drop me a reply here and I will have a look to see if I have 2decent 97s.
Cant help with the powergen but there are other makes out there , try Down to earth electrics they sell them new for what you might pay for an unknown powergen . Ive run a DTE on my flathead coupe for 4 years without a problem and fitted them to other things without any problems.
there would be postage on my prices to add . cheers for now .
hey pal thanks for your reply but decided to go for new carbs I think it will save a lot of pain,as for the other pieces Ill pic them up in the states when I go over next month.But Ive noticed your reply about the ford back plates so Im looking for the park brake levers on the shoes.Ive got the 40 style ford brakes
no worries re the headlight stand or carbs .. no spare park brake levers unfortunately, probably easier to pic them up in the states too . Good luck with the budget . I did my coupe ( steel ) all flathead V8 running gear for 8k , its doable if you have a stash of old junk to draw from .
