Results 1 to 9 of 9
Thread: Side window rubbers
    Side window rubbers
    How wide are these supposed to be ? I noticed the rear of mine has started to 'tuck' in !Name:  20241011_145404.jpeg
Size:  41.3 KBName:  20241011_145534.jpeg
    NSRA member Glyn's Avatar
    Aug 2005
    They look correct John. The bakelite/interior trim hasn't come loose?
    Zetec powered pop ON THE ROAD!!!
    Might be Glyn ? I'll have too wriggle myself in over the seat for a look !
    You were right Glyn a few screws loose !! It's not perfect tho Name:  20241014_150440.jpeg
    Aug 2005
    a little better at least. As with all the windows, they're quite tricky to fit on your own..
    Admin
    Apr 2003
    Been a few screws loose for many a year
    You were right Glyn a few screws loose !! It's not perfect tho ]
    "Praise the lowered"
    My Intro
    They look about right John. If the glass is a bit small for the window hole the rubber will tuck in.
    Did you use Arbomast between body & rubber? This will stick the rubber to the body but if you pump in a fair bit it also fills the void the rubber tucks into.
    Never needed it Mark. I wondercif the 110mph passes might have pushed them in a bit. Job for the winter
