Results 1 to 9 of 9
Thread: screws
    NSRA member pushrod's Avatar
    Aug 2019
    screws
    Whats up guys
    Ive recently bought a new 609 Mallory module for my dizzy and getting the two brass button head cap screws out that held the old module in place to the dizzy base plate was a nightmare they were seized in resulting in the heads being toast ! They are 4mm x 5mm brass button head cap screws and Mallory state to only use brass but trying to find some of these is nigh on impossible
    I can get steel but im told if i use steel it can create arcing in the dizzy !
    Anyone know where i can buy these ( in England ) or has anyone got some in a redundant dizzy i could buy ?
    Why they dont supply new ones with the module is beyond me as they know the heads are gonna chew up
    But there again Mallory's owned by Holley now so they probably couldn't care less
    Thanks
    Tony
    Aug 2019
    Hi
    Thanks i had seen those but the heads will be too high !
    Only button heads i can find is In (you guessed it ) China
    Tony
    anything here any good? uk only and i see both m4 and m5.
    https://www.ebay.co.uk/sch/i.html?_f...5&LH_PrefLoc=1
    Be 2 minutes in the drll with a file too sort that ...there only brass ..slip a couple of nuts on the thread and shape them
    Surely cheese head slotted screws would work fine? OK, won't have the possible ease of insertion of a socket but hey, that's what chewing gum, bluetack, tape, tweezers etc are for.
    Quote Originally Posted by pushrod View Post
    Hi
    Tony
    That'll be where the Mallory ones come from anyway!
    Aug 2019
    Hi all
    Reason for them needing to be so shallow headed is they have to clear the advance/retard lever and the tolerance is zero ! Its a stupid set up really !! What Ive done is put a normal Phillips m4 screw in one side which doesn't have a lever going over it and the one on the lever side Ive used one of the old button heads and cut a slot in it and put it in with a flat blade screwdriver ! Talk about a lash up !! If this works ill eat my hat !
    Good old Mallory/Holley cant even be bothered to reply to my e mail
    Thanks all
    Tony
    In this modern, plastic, world in which we live, it might be worth looking into exactly that, plastic! Lots available, if you can avoid expensive shipping! Low profile heads too.
