Results 1 to 2 of 2
Thread: Parts for sale. More stuff added.
    Guest Gary Mc's Avatar
    292ci Ford Y block, complete engine disassembled for re build. STD/STD requires grinding and boring etc. No distributor or carb. Has flywheel. £400 or sensible offer.
    Transmission adaptor - Ford Y Block to Early ford 3 Speed. £175
    Pair of old long tube headers for SBC, believed to be Jardines, £100
Size:  360.1 KBName:  IMG_6054.jpg
    1939 Ford rear Axle inc torque tube and driveshaft. No brakes or wishbones. £600ono
    1937 Ford Pick up fuel tank. Few older soldered repairs so will need a good clean and checking over. £50
    Shortened 40 torque tube, this will work in a 32 when using a 39/40 rear located 1” rearward from stock to correct the wheelbase and transmission in stock location. It consists of shortened tube, if I remember correctly rotated to position the Speedo drive to suit a 32, modified wishbones, modified 32 tubular drive shaft, 1/4’ kunifer brake lines, shortened wheel to wheel cable, one off front cable and brackets, all painted and ready to bolt in. Handbrake will connect straight on to original 32 lever (LHD) save a load of work ? £500 Or sensible offer.
    Attachment 63779
    Model A spring and crossmember. Crossmember has been trimmed and is 910mm wide. £130 not sure about shipping the spring due to weight?
    Last edited by Gary Mc; 27-12-24 at 10:22 PM. Reason: More parts & Pictures added.
    Dec 2010
    Hey Gary are the wheel supports still available cheers Fred 07891409588
