Results 1 to 5 of 5
Thread: Head light bucket paint?
    Feb 2017
    Anyone used chrome paint to freshen up! their headlight buckets, if so did it make your lights any brighter, and if so what paint did you use? Thanks.
    How about experimenting with chrome adhesive tape,as long the lenses are a bit opaque you won't see the wrinkles/joints ,powerful bulbs may affect the adhesive over time with the heat,but what's to loose.
    It isn't cheap, but cheaper than buying new buckets.
    Headlight Paint – Chroming for Headlight Reflector Optics
    adhesive aluminium tape like used for home/industrial ducting works great for pretend 'chrome'. even on curves like your headlight bowls, any wrinkles can be fully flattened with something like a wooden spoon (won't tear it). then as it's ally it' polishes to an almost mirror shine. clear lacquer for a long lasting shine.
    Feb 2017
    Thanks, Will look at all of these;
