Results 1 to 9 of 9
Thread: Radweld ? good or bad
    Feb 2017
    My rad has a small leak. is radweld a good or bad option for a fix, or should I try it and if it doesnt work take rad out and get it sorted.
    Some say it's not good and compromises the possibility of eventual repair. But if it works and gets you out of a spot who's to say it's wrong? Minor soldered repairs can't be too expensive though, if you can find somewhere that can ctually do it properly.
    NSRA member sebspeed's Avatar
    Dec 2008
    i've had good results with K seal.
    K Seal it's what the plant fitters use
    NSRA member crumble's Avatar
    Oct 2003
    Have it repaired properly.
    Real steel
    NSRA member plumpcars's Avatar
    Apr 2004
    K Seal is a more efficient product and widely used.
    Nov 2024
    It's a temporary fix. Treat is as such.
    Feb 2017
    Thanks to all.
    depends where the leak is as to whether it can be soldered properly or not. i've used both fibreglass filler and normal body filler on core leaks with good success. sniff of rattle can black and it hides well. make sure you push the filler right into the core and leave a slight bulge where the leak is/was.
