Page 9 of 44 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 879
  1. #161
    In reality, the holes wernt needed with the few gaps around the sill edge…but I still think it’s an advantage as can be a direct route out.
    tacked in the other side. That arnt the best metal work examples but hopefully will do that.
  2. #162
    Better safe than sorry Tom.
  3. #163
    do the swage lines go up into the running board or down tom? if down they can hold a little water.
    They go down to naturally help any static water drain out towards the front end where my drain holes are and also standard holes in the front of the sill. There’s so many vent points now and a nose down rake I have minimum concern. Well over the top.
  5. #165
    i guessed you had it covered but thought it was worth mentioning just in case.
  6. #166
    A good day at the workshop.
    Done some small bits of cleaning up and a bit of welding here n there on the sills, splash of primer that will be easily buzzed back off when required.
    They still hold the old and not factory new look.
    I then moved on to the chassis, with the body off I could weld some bits that were easier to get to.
    Few more bits to tinker with before the body goes back on to start the next section!
  7. #167
    Top work Tom
  8. #168
    Top work Tom _smiley:
    X2 Tom.
  9. #169
    NSRA Committee
    X3. It's a great project and following it with interest.
    Can't wait to see it on the track.
  10. #170
    Cheers guys!
    Tonight’s ideas went to plan, a little more welding on a few bits I wanted to to finish up. Working through that list!
    Another thing I wanted to do was get the lower hinge bolts out of the little sandwich plate, well the idea was just to get them out of the A post and make a new one, but once removed and seeing how they work I thought I would save the original ones!
    snapped bolts out, jobs a goodun.
  11. #171
    Thats cool dude. Good job well done. I'm sure I have the correct counter sunk bolts for them hinges.
  12. #172
    Nice work Tom, I like to keep original where possible.
  13. #173
    It feels like it’s been a while!
    Been a bit busy else where over the last 2 weeks crewing on a Super Gas/ Super Comp Roadster, building some Harley pipes and creating another injury for myself
    However, today I was back to it, thanks to Lee and John for lifting the body back over the chassis for me. Then I could get on with putting some captive threads in the new metal sills for the body to mount.
    Chucked the front on again for a quick measure up of a rad, when this engine was in The Tinsel Town Hustler I was lucky never to have cooling issues, with a large creative aluminium built rad and large Spal fans I had no worries. This should be the same, real good size rad up front.
    I also cast my eye over where I think I could run the headers, a way off that yet but I’ve build a few sets now and a lot of the time I find that’s something that no one thought of when doing the rest of the car, or it wasn’t them building them so it didn’t really matter!
  14. #174
    Coming on nicely Tom.
  15. #175
    Dec 2018
    Quote Originally Posted by tom.marg View Post
    pretty sure i did the headers/cage and a few other bits on that car a few years back.
    dorsets coming on well.is the aim for being out next year
  16. #176
    Quote Originally Posted by Nobody View Post
    You did indeed Wayne! ���� we’re just getting it launching properly with some 4 link changes and different spring rate.
    Dorset with any luck late this year, but if it’s next year it’s next year!
    im putting every hour i have at the workshop in to it really.
  17. #177
    Only a snippet at the workshop this evening but made a start on levelling up the edges for the bulk head to join too, nothing crazy but progress is progress
  18. #178
    It all needs doing Tom.
  19. #179
    It does indeed mate!
    Passenger side is tacked in, driver side welded and a little sand off, still some work to do
  20. #180
    It’s been another busy weekend at santapod crewing on the roadster however I managed to get a few hours in before to make a start on some metal work for the bulk head.
