Results 1 to 8 of 8
Thread: Glove box lid
    Mar 2008
    Glove box lid
    I?m converting my 35 ford to rhd. Has anyone got a glove box lid I can use preferably with the dash opening so can weld it into my dash tia
    PM you.
    I have a good 36 Ford RHD dash, if you're interested?
    Guest nobler's Avatar
    Jan 2004
    are you going to run the stock dials?
    Mar 2008
    Good question i think so but im not 100%. Why?
    Jan 2004
    the glove box is a ectangle
    its the same thing right and left so is the aperture
    its an obstacle illuding
    you think the hsape has no symmetry, but its the lower dash line
    i have done this and i did weld it in slightly wonky
    if you are running the stock temp guage - -isn't it mercury filled and has it might be a different length
    anyways, thats where the kids in the 50's used to get mercury from to play with.
    Mar 2008
    i thought the same but its handed, on left hand drive the glove box tappers to the right,
    Jan 2004
    yes
    35 36 pickup is a rectangle
    buy the 1.2mm steel
    erm if you go for a curved spoke banjo aftermarket wheel, they are 16'' and you can come over the whole inch to the right - -the dials will be off then see.
    if you 'just ' use a 16 inch 40 deluxe wheel - -same.
    if you find a rhd 37-40 steering box and mount - -the location will change too.
    is it going ifs?
    you have to plan it some as if you keep the stock three dials, it may all be to no avail anyhoo
    if you run pas a 16 inch wheel is too big
    anyplops of hard cheese - -can you not do the 180 degree spin round and choppy choppy
    Mar 2008
    Quote Originally Posted by nobler View Post
    yes
    buy the 1.2mm steel
    is it going ifs?
    the plan was to cut the dial cluster out and the glove box aperture and just change them over, but the glove box is handed, hence why i want a glove box, the dials arent really a problem to swop,
