Results 1 to 14 of 14
Thread: Various Chevy Parts Required
    Various Chevy Parts Required - Rochester Carb, 235ci motor, 12 bolt diff etc
    Saw Clarky's ad and thought I should have one the same, rather than posting seperately.
    On the look out out for the following:
    Rochester 'model B' single barrel carb.
    GM 12 bolt posi diff prefer 4.11 or similar.
    GM borg warner T5.
    16" beauty rings.
    Chevy 235ci straight 6 parts (stock and aftermarket) and complete engines.
    Velocity stacks - muroc 'flared' type or WHY?
    Wade blower parts (or complete).
    Cheers for looking,
    Mark.
    Reply here, PM or call/text 07876 035129.
    Guest toetag's Avatar
    you should have a pm
    What are the 250 and 292 fitted to ?
    Dec 2008
    i have a 13" trans am 83 s/wheel that im sure fits gm column i can check if you want £30 Guy
    Quote Originally Posted by hotrodguy View Post
    Sorry, should have said that I'm after an 'early' wheel, 50s 60s etc. just something a bit more interesting than the stock '41 truck item.
    Thanks anyway.
    Quote Originally Posted by toetag View Post
    Replied, thanks.
    Quote Originally Posted by kapri View Post
    Kev, 250 was the standard inline six for chevy from '67 to '79 as far as I can work out and the 292 was fitted to trucks only, from '63 - ?
    Mark.
    Terry,
    I have got this:-
    Let me know if you are interested, Austin Cambridge.
    Cheers,
    Stu.
    Quote Originally Posted by stueyT View Post
    Terry,
    I have got this:-
    Cheers,
    Stu.
    Definately interested Stu - looks nice. What type of hub does it have and how much do you want for it please.
    Mark
    More parts added.
    NSRA Committee
    You can get 16" trim rings from Arden Continental Motor Accessories in Greet, Birmingham.
    0121 706 5471
    NSRA member pistolero's Avatar
    Apr 2008
    I've got 16" ribbed rings here and various velocity stacks for 2 5/8 carbs. I'm also starting to stock straight six chevy hop up psrts. Give me a call.
    Miles
    miles@jackhammerspeedshop.com
    www.jackhammerspeedshop.com
    OFFICIAL DEALER for HOT ROD WORKS. SPEEDWAY MOTORS, MOONEYES, LIMEWORKS, HAYWIRE, GENNIE SHIFTER, DYNAMAT, TECHNOSTALGIA, AUTOLOC, PERTRONIX, PATRIOT EXHAUST, C&G EARLY FORD PARTS, OTB GEAR, SACREMENTO VINTAGE FORD, LOBROW KUSTOMS and many more.
