I milled my own intake for the blower setup on my flathead,
this design would proberly work well for you sort of a single plane intake with a adaptor plate on top for the carbs.
may lose a lot of torque running a single plane design thou
Mike, Nice job but one hell of a lump of ally!!!! Was you entering the "how much swarf can you make in one go" competition :-D
Rotten, If you believe that you can do the job, then have a go. At worst, it'll look and be totally sh*t and at best flow really well, give you excellent performance and look the dogs rear swingers (boll*x). Just make sure that you don't spend a fortune on it if you're not totally sure that you can carry it off.
Another thing, do your research and you should be able to get optimum lengths, size amd shape and make sure all the "tubes" are of equal length, that the induction pulses are sequential and even and it should better than what you can buy.
Good luck :-)
Well Ive made a start on friday before I left work. I had a college cut the base from 6mm mild steel with a plasma cutter.
You aint going no-where. Your gonna stay in this little town and die with one of my burgers in your hand.
Put some pics up when get some
