Results 1 to 2 of 2
Thread: Chevy 355 cid roller engine 390+BHP/ turn key / full show dressed short water pump
    Name:  IAN & DIANES  BEAST.jpg
    Name:  IAN  DIANE  ENGINE & TRANS & TC.jpg
    Trade: New Chevy 355cid / 390+ BHP full roller engine 100% turn key 4300 GBP landed UK
    New 355cid / 400+ BHP roller engine 100% turn key classic hot rod dress kit with cog drive system
    Quick Spec
    GM block full CNC machined all oil mods
    Scat crank 3.48 stroke
    E/W 4130 rods 5.700 / floating pins
    CL-77 bearings STD
    Speed Pro hyper pistons 9.8:1 comp & S/P moly rings
    Comp Cam hyd roller custom grind ..560 lift
    Morel USA hyd rollers
    True roller chain set 9 key crank gear E/W roller thrust button
    RPC 7 QT sump . Melling HV pump ARP drive
    NBK 200 cc runners heads full CNC 2.02 & 1.60 valves Comp roller VT Warhammer alum rollers Comp Cams adjustable guide plates.
    Revolution HEI recurved Mega Fire wires NGK plugs
    Full show dressed ally covers PVC & breather
    100 Amp chrome aten billet alum mount kit
    QFT 600 CFM carb
    Big End 110 GPH fuel pump ARP pump rod
    All lines SS braided hose with ally ends .
    Engine Hines balanced with spec sheet
    SFI flexplate ARP bolts 168 or 153 tooth
    Duralast starter
    Engine 100% turn k
    Also aval; 350TH Stage II transmission with matching 10" 2800 stall T/C both ship free with engine
    Price 4300 GBP landed UK @ Dartford or Liverpool seaports
    Finned retro look and air scoops and cog drive system aval .....
    Name:  TONY'S BEAST DONE READY TO KICK ASS.jpg
    A/C & P/S systems can be added
    Name:  CHRIS ENGINE HEADEERS 1.jpg
    Been asked can we supply A/C & remote P/S system with our engine..... yes indeed we can .
