I'm looking for a few of theses babies and wonder if anyone has any lying around or could point me in the direction of a supplier. I've looked around and can only find $50++++ kits in the US. They're standard GM items for the indicators etc. Bit crazy as I really only need one (for now, but could probably use 3) and could make alternative arrangements with a Superseal or similar connector if needs be, but not as neat and consistent with the existing.
Here's some pics. I need the female end as shown, but unused obviously They're! They're about an inch long overall. The pic with the terminal block shows them installed with a couple of the male blades which are 0.15" wide, just under 4mm.
I'm hoping some kind soul has a bunch of them in their stash that they didn't use when installing a wiring kit. Fingers crossed!!
Edit. I forgot to mention, I found an incredible uk source of electrical bits, fancy grommets, connectors galore, automotiveconnectors.com, but you guessed it, they don't list em. Scrolled through over 400 connectors to not find them!!
