Last night I used the messed up tube from the other week to see how some engine bay bars could look with similar bends, it looked like it would work, A bit of re jigging / designing and the front bars are fitting pretty well. They are notched and currently fitting ok. A Small bit of tweaking Maybe. I have made them fall to where the front cross member links the rails. These should be in soon along with the motor mounts. Then on to the front shock mounting points. Then hope it all stays level enough!
