Results 1 to 10 of 10
Thread: 1939 STEEL Topolino Coupe & Roadster bodies & Chassis, First time offered.
    Dec 2003
    First model Fiat Topolino. Perfect for your nostalgic build. Bodies 900 Quid each. Powdercoated chassis 300 Quid each. Four fenders/wings together for 200 Quid. Both bodies decent condition with work on the sills . Both bodies have had the floors patched up in the last 80 odd years , probably better to cut out and start again . For a race car you will cut out anyway. Lower doors have minimal rust, Both have good door hinges but on the grey coupe the hinges will need to be re-positioned ( use the same holes ) . Someone drilled out the mounting screws . Both bodies have door locks/handles. Size is 122 inch long ( 310cm ), 44 inch wide (112cm ), Cut off the useless rounded front under the grille will save 21 inch ( 54cm ) Can do that here if the body does,nt fit in your van or pickup. To work out distance i,m 3.5 hours from Calais , 1 hour from Rotterdam/Amsterdam. Postcode is 4005EX. 3 minutes from the freeway A15 where there is also a big hotel/casino. Then again in the past UK visitors have done the trip in one long day. PS, Man these pics are big, and i did resize too.
    Dec 2003
    Few more pics
    Few more pics, thankyou N.S.R.A.
    Apr 2024
    front and rear fender set.
    hello, I am interested in a set of fenders (front and rear), could you ship to the uk? best regards Jacqui
    Dec 2003
    Quote Originally Posted by Jacqui View Post
    I prefer local pickup. Maybe someone is just interested in a body which gives the option of the fenders hitching a ride. Wait and see.
    Dec 2003
    If your thinking about a Topolino as your new project don,t wait to long. You want to make the trip here before the bad weather starts.
    Dec 2003
    Waiting for a buyer/builder who has a vision of a little car with a big engine
    There's something wrong with peope if they can't see the potential here ...espeacially for that sort of money. I've just built 3 versions of it in my head while reading the advert!
    May 2013
    See if you can find some pictures of Jazzy nelsons car in the 50s running 9 seconds with a flathead ford thatll get them interested.
    Dec 2003
    If you did'nt find your dream Topolino at the Swap-Meet here's the solution.
    Dec 2003
    Both still here. haveagoodweekend
