Results 1 to 8 of 8
Thread: Mustang 2 IFS brake improvements.
    Nov 2024
    Hi Guys,
    Recently fitted a brand new CPP Mustang 2 IFS with standard 11'' vented disk brakes to my 55 F100 but would like to improve the stopping power if possible...its ok but does not inspire much confidence tbh.
    The servo and MC are relatively new and I have a solid pedal so don't think air is an issue.
    Any suggestions where to start please guys?
    Nov 2024
    Double diaphragm servo.
    What's the master cylinder diameter and the pedal ratio?
    Jack all 4 wheels up ,or at least one on front and rear and try to turn them whilst someone keeps the brake pedal down. Somethimes there is a valve in the system which can trip and prevent either front or rear working
    Nov 2024
    Thanks Guys for the suggestions... really helpful.
    Chris how do you check pedal ratio?
    Quote Originally Posted by M3GSXR View Post
    measure from pedal pivot to pedal pad, then measure pedal pivot to master cylinder clevis pivot. divide the first by the second to get pedal ratio.
    if the pedal's hard either the servo's u/s or the master cylinder's too large a bore size. a smaller bore master will give more travel but a better feel and more 'power'.
    to check the servo, first pull the vacuum hose and check there actually is vacuum. if not the hose could be collapsed causing a blockage. if there's vacuum press on the pedal with the engine running to check travel. turn off engine and repeatedly pump pedal, it should get progressively harder with less travel each time. if there's no difference between engine running and engine off it sounds like the servo's u/s.
    hope that all makes sense,
    Nov 2024
    Thanks Neil, I hope to be in the garage tomorrow so will follow your suggestions.
    also rally design can supply any of the very comprehensive wilwood brake kits available. the mustang 2 upgrades go much further than you will ever need so there'll be something to suit i'm sure.
