Results 1 to 7 of 7
Thread: Th400 alloy dust cover. High stall torque convertor dual bolt pattern.
    Hi more bits surplus to my needs.
    Th400 alloy torque convertor dust cover ?40 post ?5.
    Hi stall (told 2500rpm) dual bolt pattern torque convertor came with th400, tested it on my engine and engaged properly. Can't guarantee stall speed. Clean sweet smelling trans fluid in it. ?50 collect as heavy.
    Message me
    07935 127788
Size:  348.3 KBName:  20241214_152230.jpg
    Gary
    May 2013
    where are you based?
    Hawkhurst kent.
    Can take stuff to swap meet.
    Or i will be nearer you next week sudbury area
    New guest
    Mar 2023
    Dust cover sounds ok
    Will it fit a turbo GM turbo 400? I know you’ve mentioned it. Lying on my back with a torch in my mouth I’ve forgotten the bolt pattern at the back of the trans I’ve got a chrome knockoff at the moment from Taiwan ��
    Since found out its four 4wd box has 6 hole fixing for th350/400. Wont fit 2wd box, ive tried.
    May 2013
    Sorry fella i didnt see your reply,did you go to sudbury?
    Yeah mate.
