Page 122 of 125 FirstFirst ... 2272112120121122123124 ... LastLast
Results 2,421 to 2,440 of 2482
Thread: News on my pop (2)
  1. #2421
    Cool, groan!
  2. #2422
    Cheers guys
  3. #2423
    And were done. Next job !Name:  20260126_145441.jpeg
  4. #2424
    Cool
  5. #2425
    Moved the heater hoses from under the manifold to get it a bit cooler.
    Whilst in there noticed the fuel rail to regulator return was starting crack so new hose ordered.
    Stripped and cleaned injectors and fitted new O rings. Rad fitted and plumbed
  6. #2426
    Found a kink in the air pipe joiner so ordered some thicker tube for the connections but it's all too tight !Name:  20260121_144359.jpeg
  7. #2427
    Breath in a bit, or suck in the guts!
    Could gain a smidge of room with stainless and make bends up with the pie cut wedges? Might look cool too, if you like that sort of thing. Black hoses work though!
  8. #2428
    I can't see 4'' stainless being cheap tho !
  9. #2429
    About 40 squid a metre. Not exactly cheap, but not ridiculously expensive either? Ymmv.
  10. #2430
    could you squeeze the pipe into an oval to gain some room between engine and radiator? the silicon hoses and jubbly clips won't care.
    Chris i just bought 1/2 metre of ali for a tenner and it's lighter !
    Neil thats the plan for tomorrow
  12. #2432
    it makes sense, oval exhaust is available off the shelf to get bigger bore without losing ground clearance so the same principal applies to get the clearance you need.
    I don’t envy anyone making pie cuts lol been there many times and will be there again.
    I’ve even bought them pre cut before just to save time! Usually cut myself, nearly lost the end of a finger once on a pie cuts job, that’s another story haha!
  14. #2434
    Thats the sort of pies i prefer Tom
  15. #2435
    Thats funny re the mention of the pie cuts . When I read Toms post on the headers he just made I was going to ask about the pie cuts , if there was a less tedious way to make them but it seems its just part of the process . Doing it with aband saw might be easier , but I did my last lot wth a hack saw .. A proper chore . I did consider buying the redy cut wedges , but the price put me off ... I guess the challenge is why we do it
  16. #2436
    You know those clever printable patterns for coping tubes for rollcages and the likes, I imagine a clever person could devise similar for pie cutting straight tubes to make bends. Imagine, chosing the degrees of bends, number of slices etc, print out, cut to shape, fix onto tube, mark out then cut with an ultra thin cutting disc. Only one problem, does such a thing exist, or who's clever enough to sort it? Not me for sure but I'll take a commission for the idea! Wonder what Google says?
    Seen th segments for sale on ebay, kinda pricey as mentioned, but the ones that aren't full cut through so they can be bent to shape whilst not needing many limbs to keep together seem pretty neat.
    Edit. How off the pace am I? Just seen these babies and other handy things! Clever and pretty inexpensive.
    https://ebay.us/m/bmMdle
  17. #2437
    Well it's done ! MAF moved back down to filter and tubed squished. Bit of fabbing for the cold air intake !
Size:  77.6 KBName:  20260201_163549.jpeg
  18. #2438
    Quick sound check for Chris 5db down is good. And one worrying drip although the top clamp pinched up a bit more
Size:  69.7 KBName:  20260204_145847.jpeg
Size:  68.2 KBName:  Screenshot_20260204_153407.jpeg
Size:  30.1 KBName:  20260204_142131.jpeg
  19. #2439
    69.5Db? how do you know the engine is running?
    97 for mine
  20. #2440
    Nice burble at the back, rattly exhaust from inside, i'll visit my mate with a ramp !
