Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 201 to 220 of 221
Thread: My 34 Ford 5 W Coupe
  1. #201
    NSRA member 41 ford pu's Avatar
    The beginning of the end! It’s been a long time coming and I can’t wait to get behind the wheel. I have to thank Peter for all his hard work!
  2. #202
    very nice, it's one of those colours that looks black all the time except in bright sunlight
    NSRA member Acker's Avatar
    Jul 2011
    Just reread the whole thread, needed to recap. As Chris said previously "is the time line correct"?
    It's going to be a beautiful car when complete, unless it is already!
    Peter is very good
    Nice one, 41 ford pu
  4. #204
    The car has been going on for 13 years! I have hundreds , Maybee thousands of pictures detailing the work over the years. I kinda got a bit fed up at times and even at one point Maybee give up! However I had gone too far and had to Finnish car. I just stopped adding to the thread, just lost a bit of interest. I will start adding pictures that may be of interest to members. If it wasn’t for Peter, the car would never have got done!
  5. #205
    Looks stunning.
  6. #206
    Smart looking hotrod
  7. #207
    I’d forgotten about this car.. can’t wait to see it ..
  8. #208
    Jul 2011
    Quote Originally Posted by 41 ford pu View Post
    I have a very good friend who has a steel 3 window 34 and it was finished probably about 35 years ago, drove it a short amount of time then life got in the way and didn't get it out again till 32 years had passed
    He still has it and enjoys it
    So keep at it.
  9. #209
    Coupe
    Quote Originally Posted by Acker View Post
    So keep at it.
    Oh yes, it will get finnished!
  10. #210
    I thought I would show some jobs that went on along the way. The 4 fenders came from Howells sheet metal in the US. however the fronts needed work to make fit. Luckily the rears were good and needed no work.
  11. #211
    Nice one, gutting when things don’t fit but there all slightly different I guess!!
  12. #212
    I'm looking forward to seeing it, whenever that might be! I suspect the final push is happening right now!
  13. #213
    a mate restores classics (mainly fords) and says even the best new panels don't fit. body lines out, wings too short or too long, just lots of cutting about for a decent fit.
    Some past pictures, car is moving along!
    Finnished frame before green!
  15. #215
    Engine/ Gearbox
    Th 350 GM Perfomance parts 300 HP crate motor + TH 350 box. Although only done 500 miles from new, been sitting around 13 years! Lots of shiny things to bolt on!
  16. #216
    Building up of chassis
    Chassis now going together! I?m sort of getting a bit exited!, won?t be long until body is reunited! Thanks Pete!
  17. #217
    More of chassis
    Forgot these pics! Chassis is the same colour as body, rest of components are black.
  18. #218
    Searching for like button!
  19. #219
    Body now in same room as chassis!
    Well here we are, body is now in the same room as chassis! Brake lines going in at mo.
  20. #220
    Propshaft
    Propshaft done, thank you JWE Engineering, Bexleyheath.
