a milestone tonight - it's started to go back together
I decided to spray the cage where it was welded - with the gun pressure turned right down (approx 12 psi) there is virtually no overspray, so with it masked up and some dustsheets over the car and the extractor on full chat they got blown in.
Quite pleased with those - they need a bit of wet sanding & polishing to blend them in properly to the original paint but should be invisible after that's done.
A job that did not go to plan was refitting the battery tray panel - this 'should' have fitted straight back in - I did notice some screws not tightened on removal but though nothing of it. It turns out the 4 big bolt holes (now converted to 8mm Rivnuts) were drilled about 5mm out of line to the ally battery cage, and the other 8 bolts did not line up with the holes.
Trimming & re-aligning everything as well as getting the rivnuts fitted in the right place took an hour to sort out, for a job that should have taken only a minute. It's the details that soak up the time, I welded the cage in, in less than an hour for comparison.
Anyway, with that done the battery tray and the battery were refitted, new grommets fitted to the battery cables, battery wired up & cables were resecured with cable ties. Then the seatbelts were refitted to the rear mounts. The passenger seat is only loosely refitted here, as I'm held up on refitting the rear side panels as I'm still waiting on the inner B posts drying out enought to pump wax into them.
This means the side windows also cant go back in and the same for the seats as they restrict access to the side panels & windows.
With the new cage bars the seatbelts now have a clear unobstructed line to the seats, they had to bend around the old cage before.
70 hours.
Had some fun putting it into service mode and stripping it down, no obvious faults so pushed piston back and pumped it out a couple of times and it seems to be ok now - will have to keep an eye on it.
it was a long shot but I was hoping the guy who has the board of FS keys might have been there so I could have tried all of them to find the correct key. My bootlid key opens Andy's lock to 90 degrees so is probably quite close to the number he needs.
This put a real downer on events. And no, before anyone asks, I was not fitting the rubber with that hammer!
