Results 1 to 9 of 9
Thread: Need more lock on steering.
    Hi Guys just posting this as seems I can back on here a bit more frequently, anyway I posted this on Rods and Sods while not being able to get on here, sorry it looks a bit long winded. Anyway I thought might be useful to someone on here as well. I will keep it updated now. Hopefully if Forum keeps working)
    I have a classic mini steering rack on my beam axle rack and pinion conversion. I need more lock, i have removed the plastic c clip already, but still not enough lock. Any ideas.
    Cheers. G
    nobody
    Premium Member
    Joined Apr 20, 2009
    narrow the body of the rack
    blackpopracing
    Administrator
    Joined Apr 20, 2009
    Yep, what Wayne said.
    Badgrizzly
    Premium Member
    1949 AC saloon
    Joined Oct 11, 2012
    Discussion starter
    ?#4?8d ago (Edited)
    Probably dumb question, but how does narrowing body of rack help with increasing steering rack stroke? Gis a clue. I have a spare rack and willing try it, but not sure how that works.
    Cheers. G
    blackpopracing
    Administrator
    Joined Apr 20, 2009
    Narrowing the outer casing allows the inner rack to travel further = more lock.
    If you inner rack has travel of say 6" at present it can only move 3" each side. Narrow the outer casing say 1/2" each end will now give you 3 1/2" of travel, so giving you more lock.
    Badgrizzly
    Premium Member
    1949 AC saloon
    Joined Oct 11, 2012
    Cheers, that make some sense now. I assume there enough teeth on inner rack.
    mygasser
    Premium Member
    Joined Dec 4, 2009
    or leave the rack and just shorten the steering arms on the axle, that'll turn the spindle more for the same travel at the rack. it's what drifters do to get tons of steering lock. if the arms are butch enough you could just redrill them nearer to the kingpin and use a taper reamer to match the track rod end. easier to cut them down. weld a 'splint' across the welded join for additional strength.
    blackpopracing
    Administrator
    Joined Apr 20, 2009
    Personally I'd go the rack outer tube option first, it's not a stressed item and even if you did it badly it wont give steering failure.
    Neils way requires good/top welding skills and 'might' suffer cracks at the weld joint which might not be great under cornering
    mygasser
    Premium Member
    Joined Dec 4, 2009
    that's why i suggested the 'splint' which would go pretty much end to end of the arm. they're cast steel not iron so fine to weld. gary know a couple (at least) of people who could weld the arms for him.
    brading
    Premium Member
    Joined Sep 25, 2011
    You could always make new shorter steering arms along these lines. To use your present steering joints you could a welded on tapered bosses rather than the holes for Spherical rose joints.
    Badgrizzly
    Premium Member
    1949 AC saloon
    Cheers guys.
    The cut and weld arms option is a no go as they run close the the calipers and if shortened the ball joint would foul the caliper.
    I have been talking to a friend his brother sprints a mini with a 16v something engine and those fellas use a metro rack, theses are about 3 inches wider overall but have around 1 inch more rack stroke. The width is not a problem as i was using rack extenders anyway. I will just need to adjust my mountings a bit, also as the pinion is about 3 inches further to the right my steering shaft will move over and give me space for fitting close headers at a later date (fingers crossed). So just ordered one to play with.
    Onward and upward.
    Gary
    Badgrizzly
    ?#12?a moment ago
    New
    So been down garage today and done a measure up for cutting the mini rack, this will mean the pinion moving closer to the middle of my mountings and making the steering run closer to the engine (future exhaust run). I did order a Metro rack which should be with me tomorrow so over next few days gonna do a test cut and shut on the spare mini rack to see how that goes before looking at doing the metro rack if need to move the pinion inwards, but will see when I measure up if I need to.
    Cheers Guys for help.
    Hopefully you can see mine in the pic. Made from 1'' en8 and bent tosuit the ackerman angle.
    See if you can copy something similar as a mock up to give an idea of movement
    Unfortunately I can't use bolt on one as my steering goes through the stub axle as per pic.
    Are these bolted through at the other end ?
    Yep through the stub with a key way to stop them turning and a not and split pin on the end.
    You need a proper welder or. metalurgist to work out if they can be cut and welded or new made from scratch. Or find another steering rack with more rack length ?
    https://youtu.be/JSprlWdEpFs?si=R01CMLMCsEUnKQev
    Skip the roll playing in the middle ...
    can you shift the calipers to the front of the disk freeing the space to shorten the arm or bolting on a shorter alternative ?
    Js already sorted another rack as per above in post now got a metro one, already decided not to alter arms also as above.
    Red oxide cant move calipers to front due to shock go a front and calipers would hit shocks and shock mount, this was decided at outset of disc conversion.
    So hopefully going with metro rack in stead of mini rack maybe with a bit of surgery .
