the calipers arrived today, we just need the pads so we can offer them in position over the discs to make the mounting brackets.
in the interim we collected the mk3 zephyr and chrysler 300 estate. the zephyr needs some welding (as usual), the engine bay painting and building up to a 'driver' ready to go for paint. it's getting a ford essex v6 and auto box, if the engine runs ok that is. if not a rover will be going in instead. the 300 is a diesel and doesn't always turn over, when it does it's very slow and there was talk of sparks at the back of the engine so.....
pics tomorrow.
2 steps forward and one step back, lol. with the built up caliper slipped over the disc we offered a wheel onto the hub. due to the shape of the smoothie wheels the casting of the caliper touched the wheel near the middle. if you wiggled the wheel it pushed the caliper out roughly 5-6mm and then cleared fine. unfortunately the pads were then overlapping the edge of the disc by the same 5-6mm. back to the pc and we found different bmw discs, all the same specs except they're 300mm instead of 286mm diameter. so they're now ordered and on the way in 2-3 days. bit of a delay but it needs to be right and the bigger diameter will improve the braking slightly so a good thing really.
Yesterday, 08:52 PM
#1084
the new 300mm discs arrived today and they are just what the doctor ordered. with the pads at the edge of the disc the caliper has plenty of room inside the wheel now. next we moved to cad work and before long we had a template to transfer to 10mm steel plate. they're now cut and drilled to bolt to 3 of the 4 holes that used to attach the drum backplates. we just have to drill the caliper mounting holes in both brackets but that'll wait 'til tomorrow as the metric fine thread cap head bolts won't be here 'til then so no rush. once both sides are mocked up we can strip it apart and paint the brackets, hubs and brake pad shims. nearly there.
