Results 1 to 6 of 6
Thread: Blueprint Chevy 350 motor
    New guest
    Jun 2012
    Is anybody on here running a Blueprint Chevy 350 motor? I bought one for my '35 Ford 7 years ago from Roadcraft and it has been running just fine until last Sunday when the oil pressure suddenly dropped to zero. There were no strange noises and no loss of oil so it looks like the oil pump packed up.
    I've removed the engine but need to get it checked internally for any damage. Does anybody know a Blueprint service agent or a workshop with experience of these engines who can check it out.
    I have emailed Blueprint in the US and am waiting a reply and unfortunately Roadcraft are closed until 11th May. Thanks.
    NSRA member malstbird's Avatar
    A quick at home check would be to pull the distributor and use the correct tool to spin up the pump in a drill. See if you get any oil pressure that way first.
    Mal
    I was told hotrodding was expensive, I laughed.......but it wasnt for long
    I can't imagine there's anything particularly special / unique / different to a Blueprint engine to any regular SBC requiring specialist knowledge.
    I do remember hearing a sad tale of a guy getting thoroughly reamed by a garage over the "highly specialised, specially tuned" engine this particular car had. The car was I think an original AC Cobra. Those US truck engines are up there with Ferraris etc for their idiocracies!
    Moderator martin's Avatar
    Try Thunder Road in Woking, they know their engines as they work on race prep AC Cobras.
    www.thunderroadspeedshop.co.uk
    A bluepring SBC is just a SBC - nothing special except they may be tuned more.
    I'd be very suprised if the oil pump has packed up - SBC oiling is extremely reliable.
    I'd be looking at the oil sender first and then pull the dizzy to make sure the shaft is still driving the pump.
    Nov 2012
    Strange, I had that years ago on a '76 SBC, but it was not the gauge, as I could hear the tappets clacking. Shut down quick. Could find nothing wrong on stripdown, & a crate motor proved the gauge/electrics were fine. Changed the pump in the old engine, & it's fine. The only thing I could think of was that the gear on the oil pump shaft was slipping when hot .
