Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Ol Girls still coming along.
    Hi ya
    Been working on boot area, rear suspension, rear wiring, air tank install, new 15 gallon tank, fuel feed, battery fitting. Now all the ass end sorted, just gotta put boot lid back on, may fit a high level brake light in it if I can find something suitable.
    Any how here's a pic.
    Neat
    Cheers John.
    Also looks like I will be sticking with SBC as needed to take beemer engine by tommorow, but won't tie up large amount of dough and have SBC sitting about.
    Hey ho. So tommorow back down garage, fit battery clamp and bootlid, the turn Ol' Girl round and start fitting the front end back on. Would like to make a tilt front but not sure quite how that would work yet.
    Keep plugging away .. looks great . Good call to stick with the chevy ..looks like a tidy unit .
    Cheers.
    Been down garage today, had to change mini steering rack as found did not have enough lock, seems i had the sportpack rack for the 13inch wheel mini with reduced lock. Luckily i had another i could get hold of sharpish, now much better. Fitted rear wheels back on with new taller tyres, i think i like the stance, they fill out arches better. Also topped and check tranny level after changing pan to my deep pan with cooling tubes, not sure got it right yet, need to get a proper dipstick instead of this Chinese flex one. Also started to put front wings in place, well one them anyway, decided flip front gonna be a bit hard to do (which means aint gotta clue) but will try to make it so i can remove wings and nose as one peice for any engine maintenance, cos it's to difficult leaning over the wings.
Size:  459.4 KBName:  20260226_151455.jpg
    So been down garage last couple of days (well some of it anyway) fitted front gaz shocks, painted up a couple of bits i got at very good price at swap meet, edelbrock valve covers and a long air finned air filter (this had Mustang in raised letters on it so I milled those of with my router) sprayed both to match engine, both cost me ?120 I love a good deal. Started on trans tunnel and extra gauge housing. Getting there be a week or 2 before all sorted. Gotta fit rear gaz socks, order some carpet, sort steering lock.
    Heres a pic of new bits on engine.
    So now fitted inners wings i made out of ali. Finished gearbox tunnel/centre console, trimmed in leather from an old sofa. Fitted carpet today. Couldn't decide whether to go for overiders, bumpers or both, settled on both, overiders another swap meet buy 6 quid the pair. Removed old side lights and indicators, cut some slots for air flow through to discs. Fitted headlight with side/indicators round rim.
    Ordered a die nut to put some extra thread on the metro steering rack so I can shorten the arms by about inch each side and still fit my rod ends.
    Just need to fit rear bumper etc., rear shocks, clean inside of car, feed the leather seats. Getting there.
    Thats gonna turn a lot of heads , Bet your glad there was no takers for the engine
    Good to hear you are sticking with the SBC
    We have covered the essential fitting of a start inhibit switch on here haven't we,apologies if we have and I've missed it.
    Captain Scarlet is indestructible: I am not,but I'll give it a good go . Ian
    Looking good
    Cheers guys.
    Yep happy with the sbc.
    Re inhibit switch not covered, but done anyway, set up for start in 'park' .
    Hi Guys
    So finished the interior other than a bit of trim along the edge of the carpet by the doors. Fitted rear Gaz shocks took for a short run to check ride, mmmm bumpy so adjust the shocks down a bit much better. Still too bloody loud gonna have to look at sending the pipes out the back and possibly a bit more silencing.
    Then Sunday took her out for a bit of a run to Headcorn retro rides meet, ran great handled great, still need a bit more steering lock so will get on with doing the metro steering rack swap very soon. On way back ruddy fan belt went walk about!!!!! still managed to get home with the aid of a quick fix with some cable on the water pump, crank pulleys. Seems the fan belt I had, and was sold as correct for auto use turned out to be a lawnmower belt (right length though) Just ordered 2 Contitech AVX belts.
    So next step after a bit more running, will be to get over to Sittingbourne to a fella there that can set up carb properly and maybe chuck it on the dyno.
    Here are some pics of the Metro rack alongside my spare Mini one, you will see it is a bit wider approx an inch each side and the pinion is over to the right about an 1 and half ( be good for moving the bottom of the column over to miss the exhaust down pipes for when I change the manifolds in the future). I have tapped the rack arms around 1.5 inches so I can cut off the excess length to match the Mini rack width. The rack give about another 1/2inch lock length.
    Cheers Gary
    Well i tried to the other pic but this boody website still mucking about.
    Tidied up, looks like that's going too work, are you sure there's a proper thread cut on them as a lot of those have a rolled thread ?
    Got to do a further cut yet, will be using my other die next.
    Been a bit busy tidying the garage. Ordering steel for new front porch. Been to a couple of meets etc. Ordered some pipe for running the exhaust out the rear and a few fittings.
    Noticed engine bay gets ruddy hot and brake master cylinders are over the exhaust so made a wee heat shield glove type thing. Seems to help.
    Gonna look at a way of venting wings so heat does not build up behind them.
    Seem to be getting about 22mpg which I think is a result.
    So thats all for now.
    Could always go for exhaust wrap ?
    NSRA member jaymin's Avatar
    looking good
    Jsf. Already wrapped the bit where all 4 pipes come together. Was too much faff to do all the top pipes. Also it gives me a back ache leaning over those wings and down into the engine bay.
    Cheers jaymin.
    So had a rummage on the shelves and found some portholes vents from a project many moons ago. Be buggered if I know where I got them, but there they were. So out with some 2 inch masking tape, a measure, and felt tip pen, 2.5 inch hole cutter and bingo, got some venting in the wings/ engine bay. A quick mix of a small amount of 2k granite grey into the airbrush and done. A thin smear of pu, fitted into wings. Will test them out this pm. Need to make some mesh bits for the inside to stop horrid children chucking their crisp packets in them.
    So thats me done for today.
    GName:  20260728_120426.jpg
    AC becomes a Buick!!
