sniff test? ..... yes the shop inspectors are always on hand to keep an eye on progress
with the engine that bit higher it's easier to pull spark plugs, check for water and oil leaks etc so although it 'had' to be there as the build stand was the starting point it does have it's advantages.
so as you know i'm frugal (read tight, lol) so on that basis i've been looking at different hydraulic roller lifters for my fe big block engine. i can buy small block ford ones for under 100 quid whereas the fe ones are 600 quid up. it seems the lifter bodies are the same but as the lifters are spaced further apart on the big block the link bars are longer too. some on fe forums have used small block ones with no issues, others say they won't work (have they tried though?) so i thought..... it's only metal so i'd cut the link bars and add the 1/4" needed to match my engine. it means i can do the roller cam conversion for about 400 quid which is not even twice the price of a stock replacement flat tappet cam and lifters.
ok so the sbf hyd' roller lifters were offered with a discount code making them 68 quid so i bought them. but then it'd be rude not to get the cam too so...... that was 299 quid with shipping (duties/taxes this end too but...) from summit so overall not bad. obviously i'll have to get pushrods to suit but hey ho the big bits are ordered. this is the cam i chose... https://www.summitracing.com/parts/sum-8918
we checked the 'truck' clutch plate on the tremec input shaft and it fits a treat. i'll get a new one ordered before it all goes together.
i just followed up on a previous post re the clutch. i ended up ordering a full clutch kit so i could upgrade to a diaphram style pressure plate. these tend to give a lighter feel at the pedal than the stock 3 finger type. the kit from rock auto with shipping, uk duties and taxes was only ?165 so a bargain i thought. i'm finding the puzzle pieces slowly, i just need the lid off the box with the picture on so i know where they all go
Moderator
Originally Posted by
jsf55
Goodies !!
we like goodies
not an update as such but i'm trying to get a shipping price from a us rod shop to send a pair of ally heads to me. ebay is hard work but his contact details are in the listing so i've emailed direct. we'll see how it goes.
i just ordered a set of howards cams roller lifters for my fe engine. several comments had made me nervous of the cheap ebay ones so they'll be sold on.
i needed carbs for the tunnel ram and as it'll be almost exclusively a street car they needed to be a) smallish and b) holley's as i prefer/understand them. so when a small block ford polished tunnel ram came up with a pair of 390's on i did the obvious thing and tried to buy just the carbs. no dice there so i bought the lot and have advertised the manifold and filters for sale.
forgot to say they came with 2 boxes of holley jets too so that'll help with setting them up for my fe engine.
the howards hyd' roller lifters arrived today from summit. i also ordered a pushrod length checker ready for mockup time.
i'm looking into the fi-tech 2x4 efi to go on my tunnel ram in the future. i'll initially go with the pair of 390 holley's i've just bought but as (dare i say it) i want the nash to be a keeper i will swap to efi at some point over a winter. at least the holley's will sell easily as they're always in demand for rover v8's
i've done more digging and i won't be going with a fitech efi setup. the holley systems seem to have much better reviews and for the little extra it costs i'm favouring the terminator x version. any thoughts on those?
I was going to warn you about Fitech, I looed inot them a couple of years ago and they did not get good reviews.
I saee a lot of USA people using thr Holley Sniper with excellent results.
in the mean while i've ordered a 110gph, 7psi electric pump to feed the two 390 holleys i'll be using for a start.
