we've done some more surgery today cutting the other inner wing top etc away. the lower part between the 'cradle legs' hadn't been repaired this side so that's gone too. we'll trim it back fully then offer the templates up from the other side, the drivers side has a recess to clear the servo so a little different there for sure.
we only made the top section of the cradle today as a) other stuff needed doing and b) it was too hot, lol. still it all needs doing so anything's something right?
the 2nd part of the cradle is now made and both are welded in place. we'll nib the high spots off the welds and fold up the new inner wing parts next.
those templates are now transferred to steel and welded in place. too late for grinding so pics tomorrow.
well that wasn't as bad as it seemed, it's now a match for the o/s both in height and angle. we made a simple wooden frame that bolted to the strut top and sat on the chassis straight down. we cut the n/s cradle free, bolted it to the wooden frame and sat it back in place. with a couple of tacks we measured every which way and sideways comparing both sides and we're happy now. next was to cut plates for the outer chassis rail and inner wing and fully weld them in place. the legs of the cradle that weren't connected apart from 2 small bits at the top and the bottom, but nothing from top to bottom were also seam welded in place. lastly a good grind up of the welds in the engine bay and that's enough for today.
ps the second pic shows the 'backside' of most of the welding so not as neat as you'd like. we decided to leave it as it'll be hidden and will be stronger as is.
Yesterday, 10:12 PM
#1108
firstly today my ocd couldn't look at those welds under the wing, even though they won't be seen after final assembly. so we did some clean up, mainly just 'nibbing' off the high spots but it does look better. so on to the inner wings, we fitted up the templates and they fitted pretty good even to the fibreglass wing and we all know how out of kilter they can be after sitting around a while. moving on we cut the steel sheet to match, rolled/folded the inside and outside edges and they are both now bolted and tacked in place. again it was getting late and more importantly dinner was ready so there's no pics yet, lol.
neil.f
