Great stuff , looks like something that could be really satisfying . Never to old to learn![]()
Nice one Ian I thoroughly enjoyed doing the interior on my Pop, something totally different mate. Good on you for having a go.
Thanks Tim and Its still redoxide.
I must admit, I was disappointed with the first door card initially, but I worked on the bad bits and it came out like this
Looking good Ian![]()
Captain Scarlet is indestructible: I am not,but I'll give it a good go. Ian
That' door panel is pretty damn good Ian
Keep at it mate.
Thanks Ian and Tim.
The 2nd door card was worse than the 1st
The problems come when I cut out for the door pocket. For some unknown reason, the edge I've sewn around the opening hasn't come out nicely.
But I have a solution- get a bit of a wheelchair ramp for a taxi and cut it up
Then give it a polish, here it is on the drivers door :
I just need to make another to cover the multitude of sins on the passenger door, but I've run out of taxi ramps to cut up. Had to pay ?17 just to buy a bit of 3mm ally!
Here's the plastic sheeting screwed in place around the rear window to create something to attach the upholstery to. Plenty of velcro on there ready, I superglue it on, otherwise when you try to remove the material, the velcro usually stays stuck to the other velcro and pulls off where the self adhesive was.
This will start to look nicer when the material gets attached:
All machined, needs to have the window cut out. This is where it can go wrong - but I've got an idea. I'll show you next time.
Good save on the door opening! Nobody would have realised or known if you hadn't told the whole world!Do the ramps come in sizes big enough to make similar for the rear window? Could cut the cost and hassle and use flatbar, or possibly angle, but that would require welding. You could go visit your sis and swing by here and we could sort that.
Very kind offer Chris. Don't have any plans to visit my Sis but when I do go I'll definitely pass by and say hello!
The plastic sheet with the window cut out will allow me to cut and stick the material without ending up with a "thrupenny bit" shape in the corners.
Above - I was quite pleased with this, and it boosted my confidence too.
Below - its been in and out of the car many times today, getting there, but still more to do.
That fuel filler tube looks pants now! I'll have to cover it. Plenty material left so not a problem.
is it worth asking (samco etc?)if you can get silicon hose in that off white colour? if so replace the filler tube and that sorts the unsightly bit.
A bit of 4" soilpipe, with your trim on it would do it nicely.
If you need bits of ally in the future Ian, just give me a shout, it will only cost you postage.
http://www.case-design.co.uk
Hey Mark, my budget doesnt run to buying soil pipe!
Very kind offer, I reckon I'll be taking you up on that!
I covered the pipe, looks better now.
Also my speaker trims arrived today from Whengparts.
They fit here:
Ive always thought that the worst thing that can happen to a project is when the builder loses their enthusiasm.
To see how far down the page this thread had fallen reminded me how little has happened on it lately.
Its been extremely frustrating, not being able to get the Morris even to go round the block for its first drive. I'm still waiting for the manifold.
My plan was to see how it drove and then decide whether or not to keep the original leaf springs, but given the lack of progress, and noticing that there was only 3 1/4" clearance for the sump pushed me to get the front leafs uprated 30%.
I'll probably fit some sort of sump guard too.
I just sent this one to Jones Springs, they are happy for me to return it them if it needs tweaking to get the ride height where I want it.
Ive still got fiddly bits of trim to finish off, and lots of details to tidy, so I'm going back out to the garage to do whatever I can, hopefully reigniting my own enthusiasm for it. Continuing to chase the manifold.
Also, I was recently offered a Rover V8 for a good price, but it needs lots of bits, and with money tight ATM, and lack of space....So I'll probably pass on that one. Although, If anyone has a flywheel cheap i could change my mind.
UPDATE: just had a message from manifold guy, reckons it will be coming next week!
So I got the first drive in the Morris, here it is , still covered in garage dust.
Waiting on the rear leaf springs to come back now, sorting a few minor things.
Made an air filter for the little Weber.
I think I've finally got over my recent negativity with this build. The holiday helped, and I've now sorted a few little jobs, it's booked in for a rolling road session in a couple of weeks which hopefully will get it properly drivable
since my holiday a few things went wrong
The vice broke
I used a long steel tube for more leverage, and, OOPS!
Not the first time either, when will I learn?
The my trusty upright drill press did this, except that in this case it was not as a result of my stupidity:
I "fixed"it by building a static support, I knew those old iron barrel pipes from under the floor would come in handy
No windy up and down handle, adjustment by adding bits of wood
And the big one, letter from Thames water, we are losing umpteen litres of water per hour.
It turned out to be a copper pipe which was set into the concrete floor of our bathroom, (cement corrodes the copper, although it must have taken at least 30 years to get to this stage of leakage).
So I had lots of fun, ripping out bits of the kitchen to allow me to lift floorboards and dig to search for the old lead pipe.
Eventually I located it where it comes in under the front door, and fitted a new MDPE pipe. I do enjoy a challenge, and I can only guess what it would have cost to get a company in to do all the work.
Not much progress on the Morris then!
I did fit the bonnet, I'm still making up the brackets for the hold down springs. Fitment is not perfect, although I did take this photo where it looks ok.
I had fun chasing about for stuff while working on the house
Good job I removed the items before reversing into the garage!
And yes, of course, I could have cut the copper pipe in half outside Wickes to make it easier to bring home.....if only I had remembered to bring the pipe cutter with me.
Phew a bit too hot this week, loads to do working on house etc, but still managed to squeeze in a bit of Morrising.
Part of the bonnet fitment problem was the bonnet tape, it needed to be much thicker than any bonnet tape available to get the top of the bonnet aligned with the scuttle, so I used rubber, doubled up, with the bonnet tape on top.
This worked well for the top edge, but pushed the sides of the bonnet out too much, so i pulled it apart and cut one of the rubbers off on each side portion, then stuck the rest back,
A few other tweaks here and there got it this close:
I also made up brackets to attach the hold down springs to the wings, this is as good as its gonna get for now, I can always revisit this in the future for more fettling.
I fitted one of the mirrors for now, wiring up the repeater LEDs in it
Once Ive driven the car I'll decide whether vision is Ok, before going ahead and fitting the passenger side mirror.
I also fitted the seat belts, although despite them fitting perfectly in the dry build, they now didnt want to fit with upholstered panels. Here you can see Ive drawn the shape of the inertia box to cut out.
But then I realised that wasnt the problem after all, anyway, all fitted and working now.
Amazing how you work all this stuff out on the dry build, then forget stuff later!
(I totally deny this is part of getting older, its just too much going on in my head!)
Ideally I would like shorter "receiver" parts, but these came with the belts and will do for now.
