but surely the shock has nowhere near enough compression travel left for the axle to get anywhere near the chassis? at ride height the shock is compressed 1/3 of it's total travel and it can only have about 7 ish inches of total travel so will only compress a little over 4 1/2" more to bottom out. in post #83 above there appears to be about 8-9" from the axle case to the kick up which would be almost double what's needed. if you don't need the room in the car it's fine of course, but if things are tight a lower kickup would suit better. not a criticism in any way as the car's set to be bada55, just an observation
