today saw the arch reprofiled at the rear, trimmed to length both ends and welded in place. but not after picking some semi hard 'masticky' type goop out of the 3 ribs on the inner arch revealing 3 rusty holes...... of course. so we cut a 14 inch by 5 inch bit out to include all 3 holes and welded in a new section. the door corner is cut to match the other side and an angle was folded and shrunk to match the curve and welded on too. it needs a big grind up before the inner 'shut' part of the 'c' post can be made to suit the new shape.
